Static Friction of hollow sphere rolling up incline
The discussion focuses on calculating the static friction for a hollow sphere rolling up an incline. Participants clarify that the acceleration of the sphere is given by 3/5gsinθ, and that static friction, not kinetic friction, is at play due to the absence of relative motion at the point of contact. The maximum static friction is discussed as tan θ times mgcosθ, but confusion arises regarding the correct application of mass in the calculations. Ultimately, the correct force of static friction is determined to be 15.7 N after incorporating the mass of the hollow sphere. The conversation highlights the importance of understanding the relationship between acceleration, mass, and friction in rolling motion.
sweetpete28
For hollow sphere rolling up incline:
I know that the kinetic friction will equal 2/3 acceleration since:
μgcosθ=2/3a
acceleration = 3/5gsinθ
so...kinetic friction = 2/5gsinθ
But how I do calculate the force of static friction??
Would the static friction be the max static friction?
Max static friction = tan θ times mgcosθ
Would the static friction exerted by incline on the hollow sphere be the max static friction?
hi sweetpete28! :smile:
yes, the acceleration is 3/5gsinθ,
but there's no kinetic friction for a rolling object (beacuse there's no relative motion at the point of contact) …
that 3/5gsinθ is the static friction! :biggrin:
Hi tiny-tim,
So the magnitude of the acceleration is equal to the force of the static friction??
oops!
sweetpete28 said:
Hi tiny-tim,
oops! :redface: i copied the wrong line! :rolleyes:
i meant that 2/5gsinθ :smile:
But that is what I did and the answer is wrong:
For a I got 3.77 --> (3/5)gsin θ = (3/5)(9.81)(sin39.8degrees) = 3.77 (this is right)
Force of static friction = (2/5)gsinθ = (2/5)(9.81)(sin39.8degrees) = 2.51 (this is wrong)
what about the mass?
Mass of hollow sphere = 6.24kg but how does this factor in if:
μgcosθ = (2/3)a
solve for a: a = (3/5)gsinθ = 3.77 m/s^2
so Force of friction should = (2/3)(3.77) = 2.51 N...still don't understand why this is wrong...
that's an acceleration!
multiply by the mass :wink:
ok...
so Force of static friction = (m)(2/5)gsinθ = (6.24kg)(2/5)(9.81m/s^2)(sin39.8) = 15.7N...??
Right...?
should be :smile:
