The Fundamental Frequencies of Open Pipes
  • Thread starter Thread starter leena19
    Pipes Waves
The discussion focuses on the fundamental frequencies of open pipes and why the ratio of frequencies for pipes of lengths l and 2l is not exactly 2:1. The participants note that the end correction, which depends on the pipe's radius rather than its length, affects the frequency calculation, leading to discrepancies in expected ratios. Additionally, when analyzing two pipes of lengths 50cm and 100cm producing frequencies in a 1:95 ratio, there is confusion regarding the end correction value, with one participant questioning the validity of a negative end correction. The conversation highlights the importance of correctly applying equations for open pipes and understanding the role of end corrections in frequency calculations. Clarification on these concepts is necessary for accurate problem-solving in acoustics.
leena19
could someone please explain :-
1. why the fundamental frequencies of 2 open pipes of the same diameter and of lengths l and 2l are not exactly in the ratio 2:1?
2. given that 2 open pipes of the same diameter but of lengths 50cm and 100cm are found to produce fundamental frequencies in the ratio 1:95,what can be concluded from these figures? [ans:endcorrection 1.31cm]
1. v=f\lambda
\lambda/2 for the 1st open pipe= l+2e ,therefore f1=v/2(l+2e)
\lambda/2 for pipe2 = 2(l+2e),and f2=v/2(2l+2e)
f1 divided by f2 gives 2:1. since the frequency here depends on v,length and the endcorrection only,shouldn't the ratio be 2:1?
seems like I'm missing something but i can't figure out what & i haven't got a clue as to how to workout part 2.
any help would be much appreciated
I don't know but i'd say that the end correction isn't doubled when the tube length is doubled, since it changes as a function of the radius not the length.
lambda by 2 for pipe 2= 2(l) + 2e
Hmmm, An open tube resonates at the same frequency as a closed tube of half its length for open tubes, the equation you're using is for closed tubes, try it out again halving the length, you've practically got it though.
Yes.Thanx for pointing out my mistake.So after correcting it I get,
2l+2e/l+2e
Chewy0087 Re: statinary waves in open pipes
May26-09 05:41 PM
I think I've used the right equation
As For part 2)I get an endcorrection of -0.503m which is way off the answer given ,1.31cm.Can someone please check my working?
\lambda1/2=0.5+2e therefore \lambda1=1+4e
\lambda2/2=1+2e therefore \lambda1=2+4e
v/f1=1+4e
v/f2=2=4e and according to the given data f2=95f1,so after substituting and dividing one by the other I get
95(2+4e) = 1+4e
190+380e = 1+4e
e = -0.503m
My other problem is, can the endcorrection of a pipe have a negative value?
