Transforming Stress-Energy Tensors in Different Frames
Silviu
In an inertial frame O calculate the components of the stress–energy tensors of the following systems:
  1. (a) A group of particles all moving with the same velocity ##v = \beta e_x##, as seen in O.
    Let the rest-mass density of these particles be ##\rho_0##, as measured in their comoving frame. Assume a sufficiently high density of particles to enable treating them as a continuum.
##T^{\alpha \beta} =\rho_0 U^{\alpha} U^\beta##
I used the above equation, and I got the same results as in the book (as the particles can be assumed to be "dust"). However, in the MCRF, the tensor has ##T^{00} = \rho_0## and all the other components equal to 0. If I try to calculate the tensor in another frame moving with speed ##\beta## along the x-axis of this MCRF using ##T^{\alpha ' \beta '} = \Lambda^{\alpha '}_\alpha \Lambda^{\beta '}_\beta T^{\alpha \beta}##. I don't get the same result. Why is this approach wrong? Thank you!
Both methods should give the correct answer. Can you show more detail of your calculations?
We have ##\Lambda = \begin{pmatrix}
\gamma & -\beta \gamma & 0 & 0 \\
-\beta \gamma & \gamma & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1
\end{pmatrix}## so ##T' = \begin{pmatrix}
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1
\end{pmatrix}
\begin{pmatrix}
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1
\end{pmatrix}
\begin{pmatrix}
\rho_0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0
\end{pmatrix}## =
\begin{pmatrix}
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1
\end{pmatrix}
\begin{pmatrix}
\rho_0\gamma & 0 & 0 & 0 \\
-\beta\rho_0\gamma & 0 & 0 & 0 \\
0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0
\end{pmatrix}
\begin{pmatrix}
\rho_0 \gamma^2 + \beta^2 \gamma^2 \rho_0 & 0 & 0 & 0 \\
-2\beta \rho_0 \gamma^2 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0
\end{pmatrix}
Is this the matrix that transforms from the comoving frame to frame O, or does it transfrom from O to the comoving frame?
Sorry, I replied to your previous post. That is what you obtain going from MCRF to the one that is observing it (I hope I didn't do mistakes). However, when you do the other method you have the 01 and 11 entries non-zero, so I am doing something wrong here.
It helps to write the components of ##\Lambda## as ## \Lambda^{\alpha '} \, _\mu## so that the first index ##\alpha '## is the row index and the second index ##\mu## is the column index. Then you have ##T^{\alpha ' \beta '} = \Lambda^{\alpha '} \, _\mu \Lambda^{\beta '} \, _\nu T^{\mu \nu}##. You can then see that this is not the same as matrix multiplication ##\Lambda \Lambda T##. But note that
##T^{\alpha ' \beta '} = \Lambda^{\alpha '} \, _\mu \Lambda^{\beta '} \, _\nu T^{\mu \nu} = \Lambda^{\alpha '} \, _\mu T^{\mu \nu} \Lambda^{\beta '} \, _\nu = \Lambda^{\alpha '} \, _\mu T^{\mu \nu} \left( \Lambda^T \right) _\nu \, ^{\beta '} ##.
Here, ##\Lambda ^ T## is the transpose of ##\Lambda##. So the matrix multiplication is ##\Lambda T \Lambda^T##.
The other issue is whether or not you have the correct entries for ##\Lambda## for transforming from the comoving frame to frame O.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
