Sum of the friction and normal forces mechanics problem
The discussion revolves around solving a mechanics problem involving a wedge on a frictionless surface with a block on its slope. The key focus is on determining the maximum and minimum values of the horizontal force F required to keep the block at rest, considering the static friction coefficient μe. Participants clarify that both the normal force and the applied force F contribute to the block's motion due to their horizontal components. The equations derived include the relationship between the forces acting on the block and the wedge, leading to an expression for F in terms of mass m, gravitational acceleration g, and the angle of the wedge. Understanding the roles of these forces is essential for solving the problem accurately.
luiseduardo
Hi,
Can anyone explains me how to solve this problem ? I'm very confused what to do.
"A wedge of mass M subjected to a horizontal force is on a frictionless horizontal surface. Place a block of mass "m" on the sloping surface of the wedge. If the coefficient of static friction between the surfaces of the wedge and the block is "μe", find the maximum and minimum values of force F so that the block remains at rest on the wedge."
[PLAIN]http://img411.imageshack.us/img411/4226/calso.jpg
Fr = M.a
Well, I tried to do, but I have two questions:
What is the force applied to the block that will make it up? It would be a Normal or force F?
Yes, it is the sum of the friction and normal forces that contribute to the motion.
Ok, but the force F will contribute to the motion too ?
Or the force F don't acts to the motion only the Normal, is it?
Both of them will contribute since they both have horizontal components and the motion is horizontal...
Thanks, another question: We need two Normal ?
N (down) = mgcos a - F*sen a
N (up) = F*sen a + mgcos a
I found:
[mg(cos a*μe - sen a)] / (sen a*μe + cos a) =< F
F =< [mg(sen a + cos a*μe)] / (- sen a*μe + cos a)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
