Temperature change of ice water
To determine the final temperature of the watermelon submerged in icy water, the energy exchange must be analyzed using the equation Q = mcT, where c represents the specific heat capacity of water. The energy lost by the watermelon as it cools down will equal the energy gained by the water as it warms up. Given that the watermelon weighs 25 pounds and starts at 29.4 degrees C, while the water is at 0 degrees C, the setup involves calculating the heat transfer between the two. The problem emphasizes the importance of setting up the equations correctly rather than simply providing the answer. Understanding the principles of energy conservation is key to solving this type of thermal equilibrium problem.
kmarlow123
A tub of icy water at 0 degrees C hold 100 gallons. You put a 25 pound watermelon with a temperature of 29.4 degrees C. The tub is wrapped in blankets to avoid heat loss. What will be the final temperature of the watermelon, considering that a watermelon is mostly water?
Would you like to make some sort of attempt at the answer?
I am attempting to help my nephew with the problem but I can't remember how to go about setting up a problem like this, I don't need the answer, just some help on setting it up.
Sorry - there is a homework forum which puts up a template to fill in what you have done so far. There is no point in us just supplying answers to homework questions
There is an equation linking the amount of energy to the temperature change
Q = mcT, where c is the specific heat capacity of water
The energy lost by the watermelon = the energy gained by the water.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
