Converting Moon Temperatures to Celsius and Fahrenheit
In summary, The surface temperature on the moon ranges from 371 K during the day to 1.09 102 K at night. When converted to the Celsius scale, these temperatures are 97.85 C during the day and -164.15 C at night. However, when converted to the Fahrenheit scale, these temperatures are 176.13 F during the day and -295.15 F at night. To convert from Celsius to Fahrenheit, the formula is Tf = (9/5)*Tc+32, where Tf is the temperature in Fahrenheit and Tc is the temperature in Celsius.
scw287
51
On the moon the surface temperature ranges from 371 K during the day to 1.09 102 K at night.
(a) What are these temperatures on the Celsius scale?
(b) What are these temperatures on the Fahrenheit scale?
T=Tc+273.15 T=Kelvin temperature Tc=Celcius
9/5 F degrees/(1 C)
I got both answers right for part a but for part b the answer solution says that my answers are incorrect.
What I did was first plugged in each temperature given in the problem separately into the equation to find celcius. I ended up with 97.85 C and -164.15 C which were correct! Then I used the second conversion 9/5 F degrees/(1 C) to find each of the temperature for farenheight using the celcius degrees answers from part a I got 176.13 degrees F and -295.15.
I think I worked this out correctly but the key says I'm wrong
There's an offset in the F temperature scale. Water freezes at 0C, but not at 0F. Does that help?
You're forgetting that the zero points of the Fahrenheit and Celsius scales are not the same. More specifically, 0 degrees C is equal to 32 degrees F. As a result, you have to shift. I'll leave to you to determine whether to shift, then convert, or whether to convert, and then shift.
Oops
So I need to subtract 32 degrees from each answer to take an account for the freezing pt.
Not quite.
97.85 C means 97.85 Celsius degrees above freezing. When you convert these to Fahrenheit degrees, it means 176.13 Fahrenheit degrees above freezing, where freezing is 32 F. So...
first i would take the celcius and subtract 32 degrees since its above the farenheight freezing pt. and then convert to farenheight by multiplying by (9/5)...right...and in the other part i would add 32 degrees since its below the zero pt??
Both scales are equivalent at -40 degrees. Start from there and use the ratio you know. Be sure to readjust your answer to account for the 40 degrees.
No and no. The conversion algorithm is always the same, and you have got it wrong. Think about it this way: How would you convert 0C to Fahrenheit?
EDIT: By the way, I was hoping you'd complete the thought here, that was the point of my post:
Man I was making this problem much tougher than it was! thanks for your help!
o sorry, When you convert these to Fahrenheit degrees, it means 176.13 Fahrenheit degrees above freezing, where freezing is 32 F. so, Tf = (9/5)*Tc+32
This is the exact point I was getting at, and the equation you posted above is the correct conversion formula! I'm glad you arrived at it by reasoning it out, that's what I was hoping to coax you to do! :smile:
sometimes i just try to complicate problems...thanks for your help I appreciate it very much ;-)
1. How do you convert from Celsius to Fahrenheit?
To convert from Celsius to Fahrenheit, use the formula: F = (C * 9/5) + 32, where F is the temperature in Fahrenheit and C is the temperature in Celsius.
2. What is the formula for converting from Fahrenheit to Celsius?
The formula for converting from Fahrenheit to Celsius is: C = (F - 32) * 5/9, where C is the temperature in Celsius and F is the temperature in Fahrenheit.
3. How do you convert from Celsius to Kelvin?
To convert from Celsius to Kelvin, simply add 273.15 to the temperature in Celsius. The formula is: K = C + 273.15, where K is the temperature in Kelvin and C is the temperature in Celsius.
4. Can you convert from Fahrenheit to Kelvin?
Yes, you can convert from Fahrenheit to Kelvin by first converting to Celsius using the formula mentioned above, and then adding 273.15 to the result. The formula is: K = (F - 32) * 5/9 + 273.15, where K is the temperature in Kelvin and F is the temperature in Fahrenheit.
5. What is the relationship between Celsius and Fahrenheit?
Celsius and Fahrenheit are two common temperature scales used to measure temperature. The two scales intersect at -40 degrees, and the conversion between the two is a linear transformation. While Celsius is based on the freezing and boiling points of water, Fahrenheit is based on a scale where 0 represents the lowest temperature achievable by a mixture of ice, water, and ammonium chloride.
