The Impact of R5 on Req Calculation
  • Thread starter Thread starter mabdeljaber
    Calculation Impact
The addition of the R5 resistor in the circuit allows R2 and R3 to be included in the equivalent resistance (Req) calculation because it removes the short circuit created by the capacitor. Initially, with the capacitor acting as a short, R2 and R3 are effectively bypassed, resulting in a simplified current equation through R1. To analyze the circuit, the capacitor should be replaced with a wire to represent its short circuit behavior at time t=0, when it is assumed uncharged and has zero voltage. If the capacitor had an initial charge or if the analysis were at a different time, differential equations would be necessary instead of a simple short circuit replacement. Understanding these principles is crucial for accurate circuit analysis.
mabdeljaber
Consider the circuit to the right, with R5 = 119 Ω in series with the capacitor. Once again, the switch has been open for a long time when at time t = 0, the switch is closed. What is I1(0), the magnitude of the current through the resistor R1 just after the switch is closed?
I=V/R , Req=R235+R14
So what I know is that without the edition of the R5 resistor R2 and R3 are 0 because the capacitor is short circuiting them. Why does the addition of the R5 resistor cause R2 and R3 to be calculated into the Req for the current equation?
Likes Delta2
Adding R5 makes a difference because R2 and R3 are no longer shorted. Redraw the circuit with the capacitor as a "short" to find the initial Req and hence the initial current through R1 the usual way.
Likes mabdeljaber
Thank you I kind of understand that, but how do I redraw the circuit with the capacitor as a "short". I don't really understand what that looks like
Likes Delta2
Replace the capacitor with a wire.
Likes mabdeljaber
Thank you! Understood
Likes berkeman
Maybe we have to explain why the capacitor at time t=0 behaves as a short. The reason is that the capacitor is assumed to be uncharged so its voltage is zero at this time instant. So if you apply KVL for the time instant t=0 you ll see that the resulting equation is like that the capacitor is a short.
If the capacitor had some initial charge or if we were asked for the current at another time instant then you shouldn't replace the capacitor with a short. You will had to solve differential equations then (unless the charge of the capacitor at that time instant was given).
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
