The Sine question from earlier
  • Thread starter havechanged
  • Tags
    Sine
In summary, the conversation discusses the Law of Sines and the Law of Cosines, which are used in solving for angles and sides in a triangle. The Law of Sines states that the ratio of a side length to its corresponding angle's sine is constant for all sides and angles in a triangle. The Law of Cosines, on the other hand, relates the lengths of sides and the cosine of angles in a triangle. These laws are used in different situations, depending on the given information about the triangle.
havechanged
Hey! I just wanted to post what I was getting confused on, concerning Sin and the whole Soh Cah Toa thing.
The Law of Siness is sinA = sinB= sinC
a b c
and the other one was actually the Law of Cosines, which is:
c squared= a squared + b squared - 2ab cosC
cos C= a squared+ b squared- c squared divided by 2ab.
What I still don't quite know is when these laws need to be used...
Thanks!
You'd do better to use parentheses:
The sine law is (sin A)/a= (sin B)/b= (sin C)/c
where A, B, C are the measures of angles in a triangle and a, b, c are the lengths of the sides opposite those angles.
The cosine law is c2= a2+ b2- 2ab cos(C) with similar laws for the other angles. Did you notice that if C= 90 degrees, cos(C)= 0 so this becomes the Pythagorean theorem?
Solving for cos(C), it would be better to write
cos(C)= (a2+ b2-c2)/(2ab) so there is no ambiguity.
As to when you use them, the answer is- when they work! In order to be able to "solve for" one variable in a formula, you have to know all the others. The cosine law works very nicely to solve for angles if you know the lengths of the sides (SSS congruence), or to solve for one side if you know the lengths of the other two sides and the angle between them (SAS). The sine law works to solve for one side if you know one side and the angles at either end (ASA) or to solve for an angle if you know two sides and the angle between them (SAS again but now solving for the angle).
Thanks!
1. What is the sine function?
The sine function is a mathematical function that relates the angles of a right triangle to the ratio of the length of its sides. It is defined as the ratio of the side opposite to an angle to the hypotenuse of the triangle.
2. How is the sine function used?
The sine function is used in various fields such as mathematics, physics, and engineering to model and analyze periodic phenomena, such as sound waves, light waves, and other types of oscillations.
3. What is the range of the sine function?
The range of the sine function is between -1 and 1, as it represents a ratio of lengths and cannot have a value greater than 1 or less than -1. However, the sine function can take on any value between -1 and 1, including decimals and fractions.
4. What is the period of the sine function?
The period of the sine function is the length of one cycle or wave. It is equal to 2π or approximately 6.283 radians. This means that the sine function repeats itself every 2π units on the x-axis.
5. How is the sine function related to the unit circle?
The sine function is closely related to the unit circle, which is a circle with a radius of 1 centered at the origin on a Cartesian coordinate system. The y-coordinate of a point on the unit circle is equal to the sine of the corresponding angle formed with the positive x-axis.
