The slowing down of a Farady disc
The discussion focuses on the analysis of a homopolar generator's performance, particularly the slowing down of a Faraday disc when a load resistance is connected. Key calculations include determining the resistance of the disc and the potential difference between brushes, leading to the derivation of the time taken for the disc to reduce its angular speed to half. The relationship between mechanical energy loss and electrical power dissipation is emphasized, with participants discussing how to express these rates mathematically. The final integral needed to solve the problem is approached through the kinetic energy of the disc and its relation to electrical power. The conversation concludes with the participant successfully working through the problem.
Toby_phys
A homopolar generator consists of a metal disc of radius ##a## and a central axle which has radius ##a/4##. The disc has resistivity ##\rho## and thickness ##t##. It is rotated in a uniform magnetic field ##B## about an axis through the centre, which is parallel to ##B## and perpendicular to the plane containing the disc, at an angular frequency ##\omega##. Thin ring brushes make good electrical contact with the disc near the axle and near the outer rim of the disc as shown.
(a) Calculate the resistance of the disc ##R_D## measured between the brushes.
(b) Show that the potential difference between the brushes is ##(15/32)ωBa2## .
(c) A load resistance ##R_L## is connected across the generator and the drive is removed. Show that, in the absence of mechanical friction, the time ##\tau## taken for the disc to slow down to half its initial angular speed is
$$\tau =( 32/15)^2 \frac{m(R_L + R_D) ln(2)}{ 2a^2B^2} $$.
Inertia of a disc:
$$I=1/2 ma^2$$
Kinetic energy of rotating disc:
$$E=1/2 I\dot{\theta}^2$$
Electrical Power Dissipated:
$$ P=\frac{dE}{dt}=\frac{v^2}{R_l+R_D}=(\frac{15Ba^2}{32})^2\frac{\dot{\theta}^2}{R_l+R_D}$$
I have done part (a) and (b) - its only part C I need:
Energy at full speed:
$$E_1=\frac{ma^2\omega^2}{4}$$
Energy at half speed:
$$E_2=\frac{ma^2\omega^2}{16}$$
Energy lost:
$$E_2-E_1=\frac{3}{16}ma^2\omega^2=\int^\tau_0pdt=(\frac{15Ba^2}{32})^2\int^\tau_0\frac{\dot{\theta}^2}{R_L+R_D}dt$$
Basically, how do I solve that integral? I know the start and end values of ##\dot{\theta}##/
thank you
To do the final integral, you would need to know how ##\dot{\theta}## depends on time.
You have an expression for the rate at which electrical energy is produced. Can you come up with an expression for the rate at which mechanical energy is lost? How are these two rates related?
Mechanical energy is lost at the same rate that energy is dissipated through the resistances.
I could go into forces and go right back to first principles but I feel that would be far too long
You don't need to go into forces. Just work with the electrical power and mechanical power.
I thought about that but I couldn't see how to do it
You already have an expression for the kinetic energy of the disk. Can you use that to obtain a general expression for the rate of change of the kinetic energy?
Yes, I think :)
$$\frac{dE}{dt}=\frac{15Ba^2}{32}^2\frac{\dot{\theta}^2}{R_l+R_d}=\frac{15Ba^2}{32}^2\frac{4E}{ma^2(R_l+R_d)}$$
Which is seperable.Edit - I have worked through it all and it works, thank you
OK. Good work.
