Thermodynamic question: first law
To estimate the kilowatt pump needed for pumping 450 L/min of water at 20°C through a 100m elevation gain, the open system steady flow version of the first law of thermodynamics should be applied. The relevant equation is mΔh + mgΔz = Q - Ws, where Ws is the shaft work rate, m is the mass flow rate, and g is the acceleration due to gravity. The energy required to raise 1L of water by 100m is crucial for calculations. The final answer provided is -7.35 kW, indicating the power requirement for the pump. Understanding and applying these principles will help in solving the problem effectively.
Superhawkkodaka
Estimate the kilowatt pump you would need to pump 450 L/min of liquid water at 20c through a rise in elevation of 100m. Assume the water is pumped adiabatically and with negligible changes changes in temperature and kinetic energy.
answer given to us is -7.35kw..
Question.. what formula should i use?.. I am lost in this one.. please be specific guys.. I've used all i know and still can't get the answer..
Hints:
How much energy would it take to raise 1L (=1kg) up by 100m?
What is the equation that relates power, energy and time?
Likes Superhawkkodaka
You are supposed to use the open system steady flow version of the first law:
##mΔh+mgΔz=Q-W_s##
where Ws is the rate of doing shaft work, m is the mass flow rate, and h is the specific enthalpy.
Chet
##mΔh+mgΔz=Q-W_s##
Chet
weew thanks!
