Thermodynamics - Bernoulli Equation question
The Bernoulli Equation applies specifically to frictionless, incompressible fluids, while the Steady Flow Energy Equation (S.F.E.E) does not have these restrictions. The Bernoulli Equation can be derived through two methods: integrating the Euler equation under the assumption of incompressible flow or applying conservation of energy along a streamline while neglecting heat transfer, compressibility, and viscosity. Both derivations inherently ignore viscosity and compressibility, limiting the equation's applicability. In contrast, the S.F.E.E accommodates a broader range of fluid behaviors without these assumptions. Understanding these distinctions is crucial for accurate thermodynamic analysis.
engg.ques
Thermodynamics -- Bernoulli Equation question
"The Bernoulli Equation is restricted to frictionless incompressible fluids, the S.F.E.E is not".?
Explain the fact ?
There are two ways to derive the Bernoulli equation. The first involves integration of the Euler equation, during which you assume the flow to be incompressible. The Euler equations themselves are only valid for inviscid flow by definition since they are simply the Navier-Stokes equations with the viscous terms and heat conduction terms removed. The other method is to apply conservation of energy along a streamline while ignoring the effects of heat transfer, compressibility and viscosity. Either way, you have ignored viscosity ("friction") and compressibility, so the equation itself is not valid except in incompressible, "frictionless" flows.
The steady flow energy equation makes no such assumptions.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
