Thermodynamics Energy balance equation for Non - Steady Flow
The discussion centers on understanding the energy balance equation for non-steady flow in thermodynamics. The equation can be expressed in terms of internal energy (u) or enthalpy (h), depending on the perspective of the system. It is clarified that when analyzing control volumes, the work associated with material entering and exiting the system is typically included in the energy term, leading to the use of internal energy rather than enthalpy. Additionally, shaft work, such as that produced by a turbine, is acknowledged as part of the overall work in the system. The conversation concludes with a resolution of the initial confusion regarding the application of these concepts.
SWJ
Hi,
I am currently studying Thermodynamics and stumbled upon this equation and is slightly confused as to how this works. Hopefully someone can help me with the understanding.
According to this text here, if I am not wrong e can be h + ke + pe or u + ke + pe depending on where i am looking the system at. So does that mean the final equation can be equal to (m1u1 - m2u2) or (m1h1 - m2h2) depending on where i am looking the system at? Or i should just ask when would it be mh rather than mu?
Thank you very much.
Most developments of the open system (control volume) version of the first law of thermodynamics separate the work into two parts:
1. The work needed to force material (in the inlet and exit streams) into and out of the control volume
2. All other work (which is usually referred to as "shaft work.")
In these typical developments, the work in the equations is the shaft work, which is usually signified by a subscript s. The work needed to force the material into and out of the control volume is usually included in the energy term, and the term would then involve enthalpy h rather than internal energy u.
In the particularly development that you have cited, this separation of the work into two parts is not done. So the work in your equations includes the work needed to force material into and out of the control volume. As a result, the energy term involves internal energy u, and not enthalpy h. This approach is very unconventional.
Ah I see what u meant. Then are these "Shaft Work" included when say the flow is turning a turbine before exiting?
Yes. Shaft work includes that.
Alright! Thank you very much for the clarification now I have cleared up the confusion I had. :biggrin:
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
