How to Find Thevenin Equivalent Circuit | Step-by-Step Guide
  • Thread starter Thread starter kliker
    Circuit Thevenin
To find the Thevenin equivalent circuit, the voltage across the load (Vth) was calculated as 10 V by summing -10 V and 20 V. The Thevenin resistance (Rth) was determined to be 6 Ohms. The calculations appear to be correct, but there is uncertainty regarding the accuracy of the results. Further verification or confirmation from peers may be beneficial. The discussion highlights the importance of double-checking calculations in circuit analysis.
kliker
[PLAIN]http://img684.imageshack.us/img684/9092/asdrc.jpg
given this circuit find the thevenin equivalent
the 4 ohm resistor is the load
at first I found Vth which is Vth = -10+20 = 10 V
then i found Rth which is 6 Ohms
but I am not sure if I am correct
Looks good!
