How to Find Thevenin Equivalent Resistance?
To find the Thevenin Equivalent resistance, the circuit analysis involves determining the open-circuit voltage (Voc) and short-circuit current (Isc). The user attempted to calculate Voc using superposition, yielding values of 9.6V and 3.83V for different configurations. A suggestion was made to simplify the circuit by eliminating the top two loops, as the voltage sources create a supernode, allowing for easier calculations. The discussion also touched on the software used for circuit annotation, highlighting Visio as a preferred tool. Overall, the focus remains on clarifying the steps to effectively find the Thevenin equivalent.
jgv115
Where R1 = 2.4k, R2 = 2.9k, Vs1=7V, Vs2=7v and Is = 4mA
For this circuit I need to find the Thevenin Equivalent resistance.
*Just a heads up, all my loop analysis stuff is going clockwise*
I've tried everything to try to solve this problem but I still can't get it. Here's what I've tried:
To find Rth I need Voc and Isc.
So to find Voc I used superposition:
If I short circuit Vs1 and Vs2, I get Vo(1) = 2.4k * 4mA = 9.6V
If I open circuit Is and short circuit Vs2 and use loop analysis:
2.4k(i1) + 7 +2.9k(i1) = 0
Solving for i1 = -0.001321A
Therefore Vo(2) = 2.9k * i1 = 3.83V
Then I open circuit Is and short circuit Vs1 wouldn't Vo(3) just be Vs2 = 7V?
Am I on the right track or have I completely gone off course? Any help is appreciated!
The other way to find Vth is to suppress all the sources and find the equivalent resistance looking into the network at the output terminals; you don't have to determine the short circuit current.
Hi gneill,
I've thought about doing that but because of the way the circuit is built, I don't quite understand which resistors are in series/parallel with other resistors.
Can you give me some tips/hints?
Notice that Vs1 and Vs2 "isolate" the top two loops from the bottom two loops.
Any current provided by Is flows only in Vs1 and Vs2; it can't reach the bottom resistors.
If you eliminate the top two resistors and Is, the behavior at the Vo terminals is unaffected; the Thevenin equivalent is the same with the top two loops gone, and that's an easier calculation.
A hint: The voltage sources keep the potential differences between the middle three nodes at fixed values. In other words, what's called a supernode is formed by those nodes. As luck would have it the two voltage sources have the same value! And with the way they're oriented, the leftmost node must always have the same potential as the rightmost (Vo). So they are electrically the same node! There's your opportunity to not only put some resistors in parallel, but to eliminate one of the voltage supplies completely :wink:
gneill, may I ask what software you use to annotate the OP's image?
Sure. I use an old version of Visio. I copy/paste to Visio, mark it up, then copy/paste to Paint to save it as a gif. (Visio can create gifs directly, but it uses a filter of some sort that is tedious to use. With paint there are no options, just "Save as". Actually takes much less time!)
11K
