This problem is driving me NUTS
  • Thread starter Thread starter StaticShock
    Nuts
To increase the tension of the string by a factor of 4, the velocity of the object must be doubled. The centripetal force equation, Fc = M(V^2)/R, indicates that since mass and radius remain constant, increasing the force requires increasing velocity. The discussion involves calculating the period of motion and angular velocity to derive the necessary velocity change. Ultimately, the conclusion is that the stopper must spin at twice its initial speed to achieve the desired tension increase. This problem highlights the relationship between velocity and centripetal force in circular motion.
StaticShock
Alright here's the problem. An object that has 20 grams of mass and is siwnging horizontally with a 2 meter ratius. it makes 10 rotations within 12 seconds.
the question is How many times faster would the stopper have to be spun to increase the tention of the string by a factor of 4?
now, i know Fc=M (V sq'ed)/R.
Mass stays the same, so does the radious(I belive) and the tention force is = to FC so fc has to be increased by a factor of 4 . So the only real thing to change is the V.
I just don't see how.
i think you just answered your own question...
"how much faster does the stopper have to be spun" not how do you make it spin faster?
yes, but i don't know how to do it
Do I can't simply multiply V by 4 as the Square would throw it off
well i actually worked it out through the full calculations but there is a much simpler way i noticed afterwards.. Anyhoo
I started by finding the period of the motion
T = 10/12
Then the angular velocity
w = 2pi/T
then it was really plug and chug.
Fc = Mw^2r
Fc = 2.23 or somewhere around that, did in head soz.
Now you know your Force, multiply that by 4 and solve for V.
answer should be exactly 2x the intial velocity.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
