How Do You Calculate Torque in Bicycle Chain Drives?
To calculate torque in bicycle chain drives, the minimum torque on the back wheel can be derived from the pedal torque multiplied by the gear ratio, which is the number of teeth on the rear sprocket divided by the number of teeth on the front sprocket. Maximum torque on the back wheel is similarly calculated, considering the force applied by the cyclist on the pedals. The front wheel does not experience torque in this scenario, as it is assumed to be unaffected by rolling resistance or acceleration. The discussion emphasizes that the calculations focus on the relationship between pedal force and the resulting torque on the rear wheel. Understanding these principles is essential for analyzing bicycle performance and mechanics.
mazz1801
Its not an actual homework question just principals I am unclear on.
Its in relation to a standard bicycle being driven by a rider
How would I calculate the minimum torque on the back wheel?
How would I calculate the maximum torque on the back wheel?
How would I calculate toque on the front wheel?
Minimum and maximum with respect to what?
With respect to the force the cyclist applies on the pedals.
Neglecting air resistance
Front tire doesn't have any torque (ignoring rolling resistance, or acceleration of bicycle).
Rear tire torque = (pedal torque) x (number teeth rear sprocket) / (number teeth front sprocket)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
