Calculating Torque on a Potter's Wheel
  • Thread starter Thread starter chamonix
    Torque Wheel
To calculate the angular acceleration of a potter's wheel with a radius of 0.50 m and mass of 100.0 kg, the wheel's initial speed of 50.0 rev/min converts to approximately 5.24 rad/sec, leading to an angular acceleration of 0.87 rad/sec² when stopped in 6.0 seconds. For torque, the correct formula is torque = I * alpha, where I is the moment of inertia calculated as 0.5 * m * r², resulting in 12.5 kg·m² for this wheel. By multiplying the moment of inertia by the angular acceleration, the torque applied is found to be approximately 11 Nm. The confusion arose from initially using angular velocity instead of angular acceleration in the torque calculation. The final torque value aligns with the expected answer of 11 Nm.
chamonix
A potter's wheel of radius 0.50 m and mass 100.0 kg is freely rotating at 50.0 rev/min. The potter can stop the wheel in 6.0 seconds by pressing a wet rag against the rim.
a. What is the angular acceleration of the wheel?
b. How much torque does the potter apply to the wheel?
t=Ia
a=w/t
a. (50/60*2*pi)=5.235988 rad/sec
5.235988/6=.87 rad/sec^2
b. I didnt understand this portion of the question. I tried .5^2*100*5.235988 but the answer was not 11 Nm which I know is the answer. Please help! Any help is greatly appreciated. Thank you.
You want
torque = I * alpha
not I * omega, that is angular momentum. Check your calculation.
Also, if you are assuming the wheel is a solid cylindrical disk, then I = 0.5MR^2, so your above I value is not correct if that's the case.
So...in this case, i should go .5*100*.5^2=12.5?
But the answer given is 11 Nm. I don't understand. :(
You didn't multiply by alpha! torque = I*alpha. If you do that you will get the right answer. You found the right value of alpha in part (a).
Oh, ok. My fault. Ok. Alpha.
so... .5*100*.5^2*.87=10.9=11Nm! ok. Thank you!
Sorry, I must have overlooked that alpha part. Thank you.
