Total column water calculation from radiosonde data
To calculate total column water from radiosonde station data, one must utilize relative humidity, pressure, and temperature measurements at various altitudes. The process involves converting relative humidity to vapor pressure as a function of altitude and then calculating precipitable water vapor (PWV) within specified altitude intervals. Integration of these values over the desired altitude range will yield the total column water. For those seeking free software options, there are tools available that can assist in this calculation, though specific recommendations were not provided in the discussion. The goal is often to compare the PWV derived from radiosonde data with that obtained from GPS receivers for validation purposes.
saeed_abbasy79
hello,
i want to calculate total column water from a radiosonde station data. data are relative humidity, pressure and temperature in various altitude. my course is not physics or meteorology. please help me. is there a free software?
As your sonde gains altitude, you're going to be sampling a variety of air masses moving in a variety of directions, i.e., generating a meaningless number. Do you have some more specific purpose you can give us?
I estimate precipitable water vapor with a GPS receiver and i want to Compare with radiosonde PWV.
I think that i must calculate Precipitable water vapor in the interval of two altitude and then integrate them (in radiosonde data)
Convert relative humidity to vapor pressure as a function of altitude, and you should get what you're after once you sum/integrate over whatever altitude interval is of interest.
Likes saeed_abbasy79
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
