Transition energy estimation based on bond length
4 replies · 2K views · last reply
hanhjung99
Moved from another forum. No template.
I come across this question in a textbook. Somehow my result is way off from the solution answer. I used the energy formula for particle in a box with n(Initial) = 22 and n(End) = 23, the calculated box length is 732 pm. I arrived at an answer of 39.3 nm. The answer from the answer book is but 239 nm. Thanks for the help
  • Textbook problem P16.4 text asking for particle-in-a-box energy levels of the pi-network in hexatriene (C6H8), box length from 135 and 154 pm bond lengths, and the wavelength for the ground-to-first-excited transition compared with 240 nm.
:welcome:
Our rules say that you must show us your work, not just your answer, before our helpers give help.
anorlunda said:
:welcome:
  • Handwritten working on lined paper: a hexatriene-type molecule sketch with bond lengths 135 pm and 154 pm, pi electron count 8 + 6 = 14, n_E = 22 and n_F = 23, then a particle-in-a-box calculation of Delta E and wavelength lambda giving about 3.9 x 10^-8 m.
You're making it hard for would be helpers. Can you rotate that image 90 degrees, crop,it and enhance the contrast?
We are volunteers here. If a helper thinks your post is difficult, he/she can just skip,it.
Edited image
  • Handwritten particle-in-a-box calculation on lined paper: structural formula of C6H8 with bond lengths 135 pm and 154 pm, 44 electrons giving 22 levels, box length 732 pm, and wavelength λ = 3.93 × 10^-8 m (39.3 nm).
