Triple Integral and finding the average
gipc
Solve the Integral in cylindrical coordinates
∫∫∫ dxdydz/(sqrt( x^2 + y^2 + (h-z)^2)
B
Where B is the Ball with a Radius R around (0,0,0), and the parameter h is greater than R.
And then infer the average on that ball B with radius R of the distance opposite to the point (0,0,h).
I have these so far:
Using Cylindrical Coordinates,
∫∫∫B dV/√(x² + y² + (h-z)²)
= ∫(θ = 0 to 2π) ∫(z = 0 to R) ∫(r = -√(R² - z²) to √(R² - z²)) (r dr dz dθ) / √(r² + (h-z)²)
= 2π ∫(z = 0 to R) ∫(r = -√(R² - z²) to √(R² - z²)) r dr dz / √(r² + (h-z)²)
= 2 * 2π ∫(z = 0 to R) ∫(r = 0 to √(R² - z²)) r dr dz / √(r² + (h-z)²), by evenness
= 4π ∫(z = 0 to R) √(r² + (h - z)²) {for r = 0 to √(R² - z²)} dz
= 4π ∫(z = 0 to R) [√((R² - z²) + (h - z)²) - √(h - z)²] dz
= 4π ∫(z = 0 to R) [√((R² - z²) + (h - z)²) - (h - z)] dz, since h > R > r
= 4π ∫(z = 0 to R) [√(R² + h² - 2hz) - h + z] dz
= 4π [(-1/(3h)) (R² + h² - 2hz)^(3/2) - hz + z²/2] {for z = 0 to R}
= 4π {[(-1/(3h)) (R² + h² - 2hR)^(3/2) - hR + R²/2] - (-1/(3h)) (R² + h²)^(3/2)}
= 4π [(-1/(3h)) (h - R)³ - hR + R²/2 + (1/(3h)) (R² + h²)^(3/2)].
Now, is that solution correct? Is there a way so simplify things? And from there, how do I find the average?
Isn't \sqrt{x^2+y^2+z^2} the distance from the origin to the point (x,y,z)?
So \sqrt{x^2+y^2+(h-z)^2} would be the distance from (x,y,z) to (0,0,h)?
So your integral is just summing all these distances ... how do you find an average value by integration?
Same kind of problem, slightly different way:
http://www.mathpages.com/home/kmath324/kmath324.htm
B
= 2π ∫(z = 0 to R) ∫(r = -√(R² - z²) to √(R² - z²)) r dr dz / √(r² + (h-z)²) ...
It looks like you have only integrated over the top half of the Ball.
The limits on z should go from -R to R .
I think the final answer is still correct, no?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
