Triple integral over a sphere in rectangular coordinates
Batmaniac
Evaluate the following integral:
<br /> \iiint \,x\,y\,z\,dV<br />
Where the boundaries are given by a sphere in the first octant with radius 2.
The question asks for this to be done using rectangular, spherical, and cylindrical coordinates.
I did this fairly easily in spherical and rectangular coordinates, except for the fact that I got two different answers and I can't figure out where I went wrong! That's not a problem though because I can fix that.
How would I do this problem in rectangular coordinates? My integral would look like this:
<br /> \int_{0}^{{\sqrt{4-x^2-y^2}}}\int_{0}^{{\sqrt{4-x^2-z^2}}}\int_{0}^{{\sqrt{4-z^2-y^2}}}xyz\,dz\,dy\,dx<br />
Which, without some clever transformations and an extremely messy Jacobian calculation, looks unsolvable.
I think you need to rethink your bounds on that one...
How does this look then?
<br /> \int_{0}^{2}\int_{0}^{2}\int_{0}^{{\sqrt{4-z^2-y^2}}}xyz\,dz\,dy\,dx<br />
Hmm, MATLAB tells me that's zero.
Your dy limit should depend on x.
That would be over a square in the xy-plane rising up to the sphere.
Projecting the sphere into the xy-plane gives you the quarter circle x2+ y2= 4, with 0\le x\le 2, 0\le y\le 2. You can let x go from 0 to 2 but then, for each x, y ranges from 0 to \sqrt{4- x^2}.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
