Triple Integration: Transform Equation to Spherical Coordinates
The discussion focuses on transforming a complex integral from Cartesian to spherical coordinates, specifically for calculating the electric field due to a Gaussian charge distribution. Participants clarify the meaning of variables such as \vec{x}, \vec{x'}, and \vec{x}_0, with \vec{x'} representing the integration variable as a position vector. The integral's limits extend to infinity, and the volume element is confirmed as d^3x' = dx' dy' dz'. One user suggests using the electric potential for easier integration, leading to a potential expression involving the same Gaussian charge density. The conversation highlights the challenges of handling the Gaussian function within the integral transformation.
big_gie
Transform the equation from cartesians coordinates to spherical coordinates.
\int_\infty\int_\infty\int_\infty<br /> exp\left\{<br /> \frac{-\left| \vec{x&#039;}-\vec{x}_0 \right|^2}{2 \sigma}<br /> \right\}<br /> \frac{\left( \vec{x} - \vec{x&#039;} \right)}{\left| \vec{x} - \vec{x&#039;} \right|^{3}} d^3x&#039;<br />
I'm confused by the \vec{x}, \vec{x&#039;} and \vec{x}_0... I know it can be done: nothing depends on the angle here, so I should just get something depending on \vec{r}.
Thank you for any hints...
I'm equally confused by your integrand expression. It's supposed to be dxdydz isn't it? And what are the limits of your integration? And what does x' mean as both a scalar variable or vector function variable?
Hi Defennder, thanks for your reply.
Yes, d^3x&#039; is indeed dx&#039;~dy&#039;~dz&#039;: a volume element.
The integration is over infinity.
\vec{x&#039;} is the integration variable. It is a position vector (x&#039;,y&#039;,z&#039;).
Maybe I'll explain more the problem...
The integral is the electric field at position \vec{x}, caused by a charge distribution of gaussian shape:
\vec{E}\left(\vec{x}\right) = <br /> k \int_{x&#039;=-\infty}^{\infty} \int_{y&#039;=-\infty}^{\infty} \int_{z&#039;=-\infty}^{\infty}<br /> \rho\left(\vec{x&#039;}\right) \frac{\vec{x} - \vec{x&#039;}}{\left| \vec{x} - \vec{x}&#039;\right|^3} ~dx&#039;~dy&#039;~dz&#039;
<br /> \rho\left(\vec{x}\right) &amp; = &amp; \rho_0 \exp\left(<br /> -\frac{\left(\vec{x} - \vec{x_0}\right)^2}{2 \sigma^2}<br /> \right)<br />
where:
\vec{x} is the position where the field is wanted;
\vec{x&#039;} is the integration variable;
\vec{x_0} is the particle center;
\sigma is the particle width.
I think I'll use the potential instead, for an easier integration:
\vec{E}\left(\vec{x}\right) = - \nabla \phi\left(\vec{x}\right)
<br /> \phi\left(\vec{x}\right) = <br /> k \int_{x&#039;=-\infty}^{\infty} \int_{y&#039;=-\infty}^{\infty} \int_{z&#039;=-\infty}^{\infty}<br /> \rho\left(\vec{x&#039;}\right) \frac{1}{\left| \vec{x} - \vec{x}&#039;\right|} ~dx&#039;~dy&#039;~dz&#039;<br />
I've done a variable change for \vec{x} - \vec{x}&#039; but then I'm stuck in the gaussian...
Thanx for any hints.
(Sorry if any mistakes have slipped, I'm writting this from memory and it's getting late...)
