Two astronauts angular momentum unkown r
The discussion involves two astronauts connected by a rope in space, initially orbiting their center of mass at an angular speed ω0. When one astronaut pulls the rope, they reduce the distance between them to 0.668d, prompting a need to calculate the final angular speed as a fraction of ω0 using angular momentum conservation principles. The conversation highlights the challenge of determining the initial distance for calculations related to rotational dynamics. Participants suggest using the initial distance as d and the final distance as 0.668d to facilitate the calculations. The importance of careful reading and understanding of the problem setup is emphasized throughout the discussion.
diego1404
Two astronauts, each having a mass M are connected by a length of rope of length d have a negligible mass. They are isolated in space, orbiting their center of mass at an angular speed of ω0. By pulling on the rope, one of the astronauts shortens the total distance between them to 0.668d. Treat the astronauts as point particles (in terms of their moments of inertia).
a) What is the final angular speed of the astronauts as a fraction/multiple of ω0 ? (E.g. If you find that the final angular speed is half the initial angular speed enter 0.5.) Use angular momentum conservation.
b) What work does the astronaut do to shorten the rope as a multiple/fraction of the quantity Md2ω02 (which has dimensions of energy)?
essentially i ended up having the equation
initial---->Iw = Iw <----final
2mr^2w = 2mr^2 w
Wf = (R/Rf)^2 * W
as you can see the problem comes when you realize that you don't know what the initial distance is and that almost all the rotational dynamics needs distance. so what can i substitute for the initial distance
hi diego1404! :smile:
diego1404 said:
… as you can see the problem comes when you realize that you don't know what the initial distance is and that almost all the rotational dynamics needs distance. so what can i substitute for the initial distance
call the initial distance d, and the final distance 0.668d :wink:
every single time... thank you. i have to remind myself to read things properly
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
