How Do Friction, Tension, and Pulley Dynamics Affect Acceleration?
The discussion focuses on a physics problem involving a block on a table, friction, and a pulley system. The user attempts to derive the acceleration of the system but encounters an error in their calculations. Key forces considered include friction on the first block, gravitational force on the second block, and the torque from the pulley. Suggestions for improvement include applying Newton's second law separately to each mass and the pulley to derive the correct equations. The importance of ensuring consistent units for torque and force is emphasized to avoid errors in the calculations.
EstimatedEyes
A block of mass m1 = 3 kg rests on a table with which it has a coefficient of friction µ = 0.54. A string attached to the block passes over a pulley to a block of mass m3 = 5 kg. The pulley is a uniform disk of mass m2 = 0.4 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
F=ma
tau=I*alpha
I(disc)=(1/2)mr^2
alpha*r=a
I determined what I thought were all of the forces acting in the direction of acceleration (friction on block 1, gravity on block 3, and the torque causing the angular acceleration of the pulley. From this I derived the equation:
(m1 + m3)a = m3g -m1gµ - I*(a/r)
and then solved for a
a = (m3g-m1gµ)/(m1 + m2 + .5*m2r)
but that did not give me the right answer; where did I go wrong? Thanks!
Redo your derivation. For one thing, torque and force have different units and thus cannot be added together.
I recommend that you separately apply Newton's 2nd law to each mass and the pulley. By combining those three equations, you'll derive the equation that you want.
