Which Way Will the Disk Rotate With Two Hanging Masses?
  • Thread starter Thread starter ariclaire
    Disk Two masses
To determine the rotation direction of a circular disk with two hanging masses, the forces F1 and F2 must be calculated using the formula F = mg, where m is the mass and g is the acceleration due to gravity. The torque for each force is then found using the equation T = rFsin(phi), where r is the distance from the axis of rotation and phi is the angle. The calculated torques will indicate the net torque direction, which ultimately determines the disk's rotation. The discussion highlights confusion about the initial steps in solving the problem, emphasizing the need to calculate forces and torques accurately. Understanding these concepts is crucial for predicting the disk's rotational behavior.
ariclaire
A circular disk has two masses acting on it, m1=10g, m2=50g. The forces caused by these masses are 4.5cm (F1) and 6.8cm (F2) away from the axis of rotation (center). The angles are 130 degrees (F1, and on outer side away from center) and 98 degrees (F2, also on outer edge away from center). Calculate F1 and F2. Which way will the disk rotate?
T=rFsin(phi)
I wasn't even really sure where to start with this one. Don't know if I'm missing some info or what.
Start by calculating the two forces using gravity (mg). Then find torque from these forces.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
