Two masses sliding in a track connected by springs
To find the frequency of oscillation for two masses connected by a spring, the equation w^2 = k/m is relevant, where k is the spring constant and m is the effective mass. The center of mass (c.o.m) of the system remains stationary due to the absence of external forces. A suggested approach involves using the reduced mass principle and defining an appropriate coordinate system to derive the equations of motion. Additionally, the effective spring constant can be adjusted based on the configuration of the system. Understanding these concepts is crucial for solving the problem effectively.
akinoshigure
Two masses m1=100g and m2=200g slide freely in a horizontal frictionless track and are connected by a spring whose force constant is k=.5N/m. FInd the frequency of oscillatory motion for this system.
I don't really know how to go about this problem. I'm assuming that the equation to find the frequency would be
w^2=k/m
I did try making the center of mass, but I wasn't sure if it was even necessary. I ended up with xcom=2/3*d where d is the distance from m1 to m2.
Any help or hints would be great. I just don't feel like banging my head on the desk anymore...
O.K.
The c.o.m will remain stationary as there is no external force on the system.
Take force constant of that part of the spring only, which is (k d)/(2/3*d) = 3k/2
{?think}
Now with this k find frequency for 100 gm block.
One more way is there. Consider it as two body system and use reduced mass principle.
Start by defining a clever coordinate system and writing the equations of motion. Then you'll have to find a clever way to solve them. hint: Involves a change of variable.
As for "trying to make the center of mass", whatever that means, note that the net force on the system will always be 0, hence the CM will always remain in the same place. This is basically the most important point to realize in defining your clever coordinate system.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
