Two Particle Schrodinger Equation in Polar Coordinates
naharrison
Consider two non-identical, non-interacting particles of mass M that are constrained to move on a circle of radius R. Write down the Schrodinger equation for this problem and find the eigenfunctions and energy levels of this system.
(see below)
I started by defining a coordinate system where the circle is centered at the origin of the x-y plane (z = 0). The particles don't interact and there is no external potential so V = 0. Also, using spherical coordinates, r = R, \ \theta = \frac{\pi}{2} . I then wrote down the Schrodinger equation:
[-\frac{\hbar^2}{2m_{1}}\nabla^{2}_{1} - \frac{\hbar^2}{2m_{2}}\nabla^{2}_{2} + V]\psi(r,\theta,\phi) = E\psi(r,\theta,\phi)
The Laplacian in spherical coordinates is:
\frac{\partial^2}{\partial r^2} + \frac{2}{r}\frac{\partial}{\partial r} + \frac{1}{r^2}[\frac{1}{sin\theta}\frac{\partial}{\partial\theta}(sin\theta\frac{\partial}{\partial\theta}) + \frac{1}{sin^2\theta}\frac{\partial^2}{\partial \phi^2}]
Since r and theta are fixed, the Schrodinger equation reduces to:
\frac{1}{2}(\frac{\hbar}{R})^2(m_1 + m_2)\frac{\partial^2\psi}{\partial\phi^2} + E\psi = 0
letting a = \sqrt{\frac{2R^2E}{\hbar^2(m_1 + m_2)}} the solution of the Schrodinger equation is:
\psi = Ae^{a\phi} + Be^{-a\phi}
This is where I get stuck. I assume the next step is to apply boundary conditions which will then give the energy levels. How do you do this in this situation? I tried:
\psi(0) = \psi(2\pi)
\frac{\partial\psi(0)}{\partial\phi} = \frac{\partial\psi(2\pi)}{\partial\phi}
but the results didn't make any sense. Any thoughts? Thank you in advance!
How did you get the mass to the numerator?
You are missing an i in both terms. Also please check the dimension of a. With that applying b.c. should give you the quantisation condition on E.
Thank you for your help. Both careless mistakes, I need to be more careful. Now I am trying to determine the degeneracy of the first three energy levels. Here is my logic, I am not sure if it is correct.
Ground state degeneracy = 2. Neither particle is excited, but since they are distinguishable you could swap their positions and get a different state with the same energy. So, state 1 = particle X in ground state at position 1 and particle Y in ground state at position 2; state 2 = particle X in ground state at position 2 and particle Y in ground state at position 1.
First excited state degeneracy = 4. One particle is excited and the other one isn't, and again you can flip their positions to get another state.
Second excited state. This one is more difficult. It seems to depend on which of the following situations has a larger energy, one particle in its second excited state and one particle in its ground state, or both particles in their first excited state. In the first situation the degeneracy would be 4, in the second situation the degeneracy would be 2.
Here is one more thing that is confusing me. After I correct the mistakes from my first post I get the energy to be E = \frac{\hbar^2 n^2}{4MR^2} \ , \ n = 0,1,2,3,... Clearly there is a unique value of energy for each value of n. How could you determine the degeneracies just from this equation for the energy levels? Thanks again for any feedback.
where m_1 = m_2 = M \ (this is given in the original question) sorry for not mentioning that.
fyi I am just learning this too
Was V=0 given in the problem?
The particles are confined to a circle of radius R, I would have guessed there would be an infinite potential barrier at r=R.
regardless, from what I have learned thus far,to calculate the eigenfunctions and energy levels, consider a general wave function that describes a system two particles
psi( r1,ms1, r2,ms2) i think you only need polar rather than spherical coordinates
where r1 is the radius of the first particle, ms1 is the internal angular momentum of the first particle and so forth
Since the particles are non interacting, the ms term can be ignored
leaving psi(r1,r2)=psi(r1)psi(r2). I believe you solve psi(r1)psi(r2) separately, but they should be the same wave function
I would solve the energy levels for each particle separately, taking
E(total)=E1n E2n
Also, exchanging coordinates of non-interacting particles won't affect the probability distribution
hence psi(r1,r2)=psi(r2,r1)
V=0 was not explicitly given, but the particles do not interact and and no other external potential is given. I think you are confusing ON a circle with INSIDE a circle. If they were confined to move inside a circle, then yes, I think there would be an infinite potential at r=R. However this just has the particles moving ON the circle. It is like a particle moving in just the x-direction in Cartesian coordinates, there is no need to assume infinite potential barriers keeping it on the x-axis.
I think you are right about solving for the energy levels separately. This would lead to:
E^{(1)}_n = bn^2 and E^{(2)}_{n'} = bn'^2 where b = \frac{\hbar^2}{2MR^2}. Therefore,
E^{total}_{n,n'} = b(n^2 + n'^2)
Therefore, the ground state is n = 0 \ , \ n' = 0 leading to E = 0
And the first excited state is n = 1 \ , \ n' = 0 OR n = 0 \ , \ n' = 1 leading to E = b
And the second excited state is n = 1 \ , \ n' = 1 leading to E = 2b
And the third excited state (which is not asked for in the problem, but I will include it anyway) is n = 2 \ , \ n' = 0 or n = 0 \ , \ n' = 2 leading to E = 4b
If g_n is the degeneracy of the n^{th} excited state then g_0 = 1, \ g_1 = 2, \ g_2 = 1. Is this correct?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
