Uniform acceleration vector problem
An object accelerates uniformly at 8 m/s² at an angle of 130 degrees for 5 seconds, reaching a velocity of 20 m/s at 143 degrees. The initial velocity was calculated using vector components, resulting in approximately 21.1 m/s at an angle of 27.4 degrees west of north. For displacement, the user initially used the final velocity instead of the initial velocity in their calculations. A correction was suggested to use the proper formula for displacement, which incorporates the initial velocity. The user expressed gratitude for the feedback and plans to apply the suggested formula.
DB
i just need some1 to tell me if i did something wrong and if i did a hint in the right direction would be great.
an object accelerates uniformly at 8 m/s^2, 130 degrees for 5 seconds until it reaches a velocity of 20 m/s, 143 degrees.
Calculate: a) the intial velocity b) the displacement at the end of the 5 seconds
a) i decided i was going to use a=\frac{v_2-v_1}{\Delta t}
so i had to turn the vectors to rectangular form, so i worked out their components using trig:
8, 130 degrees = [-5.14, 6.13]
20, 143 degrees = [-16, 12]
so i filled in wat i know:
[-5.14, 6.13] =\frac{[-16, 12] - [x,y]}{5}
5*[-5.14, 6.13]=[-16, 12] - [x,y]
[-25.7, 30.7]-[-16,12]=-[x,y]
\frac{[-9.7, 18.7]}{-1}=[x,y]
[9.7, -18.7]=[x,y]
so know i got the components of the intial velocity, to put them in polar form:
pythagorus
v_1=\sqrt{443.78} \sim 21.1 m/s
using tan inverse i get 27.4 degrees for the angle and because x is negative and y is positive you get 21.1 m/s , West 27.4 degrees North
that wat i get for "a"
b) i chose to use \Delta d= v_2 \Delta t - \frac{1}{2}a \Delta t^2
subsitute:
\Delta d= [-16, 12]*5- \frac{1}{2} [-5.14, 6.13]*25
\Delta d= [-80,60]-[-64.25, 76.63]
\Deta d=[-15.75, -16.63]
so
Delta d= ~ 23 m W 46.5 degrees S
howd i do? I am not so confident
I haven't got a calculator with me, but assuming you typed it in right, I agree with you answer to (a). However, your equation for displacement has to use initial velocity (whereas you used final velocity), you can prove this with a velocity-time graph. If you want the graph tell me and I'll add it on in the morning (UK time).
d = V(initial) x T + 0.5 x A x T^2 (sorry about the crude formula)
I think you should be more confident, your thinking is spot on (especially how you approach with questions, just need to learn the formulas) ;-)
Regards,
Sam
my apologies about the thread being posted three times, i don't know why but everytime i edited the thread it just posted a new 1, sorry.
thanks for the reply BerryBoy, ill apply that formula, don't worry bout the graph, thanks for the offer though :)
