Uniform Ciruclar Motion (whirling cord)
  • Thread starter Thread starter KatieLynn
    Motion Uniform
A 200g object is being whirled in a horizontal circle with a diameter of 2.4 meters at a rate of 3 revolutions per second. The velocity of the object was calculated as 22.3 m/s, and the acceleration was found to be 425.6 m/s². The confusion arose in calculating the tension in the cord, where the weight of the object was incorrectly included in the horizontal force calculations. The correct approach requires recognizing that the centripetal force acts horizontally, while the weight acts vertically. After correcting the mass to 0.2 kg, the tension in the cord was determined to be 85.1 N.
KatieLynn
A 200g object is tied to the end of a cord whirled around on top of a horizontal and frictionless table top in a 2.4 diameter circle at 3 rev/s. Determine a) the velocity of the object b)t he acceleration of the object and c)t he tension in the cord.
Vc = (2*pi*r)/T
Ac = (Vc^2)/R
Fnet = MA
Ft - Fg =MAc
So for A) I got Vc = (2*pi*1.2)(1/3) which equals 22.3 m/s
Then for B) I got Ac=(22.6)^2/(1.2) which equals 425.6 m/s
Now here's where I get lost
I tried doing this but it doesn't come out right...
Fnet = MA
Ft - Fg =MAc
Ft - 196.2 = (20)(425.6)
which means Ft = 8708.2N, I know the answer should be Force of tension = 85.1N, I'm not sure what I'm doing wrong.
200g=.2kg. Change to kg if you want the answer in Newtons. Watch your units.
Vc = (2*pi*r)/T
Ac = (Vc^2)/R
Fnet = MA
Ft - Fg =MAc
Fnet = MA
Ft - Fg =MAc
you did fine in a and b. In c, however, you included the weight, but since the object is being twirled on a horizontal tabletop, the centripetal force and acceleration acts horizontally. The weight acts vertically.
Yes, there's that too. I missed it.
Ahh that you so much. I, for some reason, was converting 200g to 20kg, now that I switched it to .2kg and took out the force normal I got the right answer. Thank youuu :)
