Unusual question regarding torque
  • Thread starter Thread starter physics2004
    Torque
The discussion focuses on calculating the accelerations of two equivalent masses placed at two corners of an equilateral triangle, with the third corner fixed. When the system is released, gravity acts downward, affecting the motion of the masses. The torque and moment of inertia around the fixed point are essential for determining the rotational acceleration. The relationship between torque, moment of inertia, and rotational acceleration is emphasized, using the formula torque = moment of inertia × rotational acceleration. Understanding these concepts is crucial for solving the problem accurately.
physics2004
two equivalent mases, m, are placed on two corners of a triangle with 3 sides each of length a (i.e an equilateral traingle). The third corner is fixed (not free to move).
The triangle orginally starts with one side perfectly vertical. Gravity acts downward intially, calculate the accelerations of the masses right after the system is let go .
Find torque and moment of inertia around the fixed point
Use torque = moment of inertioa X rotational acceleration
