Using Atwood's Machine to Measure Time Intervals
  • Thread starter Thread starter maxxed
    Machine
To use an Atwood's machine as a timer for a vertical fall of 1.30m in 10 seconds, the acceleration can be calculated using the formula a = (2h)/t², resulting in an acceleration of 0.026m/s². This acceleration can be related to the masses M and m using the equation a = (M - m)/(M + m) * g, where g is assumed to be 9.80m/s². By substituting the calculated acceleration into this equation, a relationship between the two masses can be established. The discussion emphasizes that while this relationship is crucial, no additional information is provided to determine specific values for M and m. The focus remains on deriving the mass relationship necessary for the timing mechanism.
maxxed
Using this site as a reference: http://hyperphysics.phy-astr.gsu.edu/hbase/atwd.html
Can somebody show me how to solve this:
Suppose you don't have a watch, or a timer, and you want to use an Atwood's machine as a timer to give an accurate time interval (for the vertical fall) of t = 10.0s. Suppose the vertical fall, y, is 1.30m. Determine values of M and m which would make t - 10s.
Some formulas
a = (2h)/t2
g= a x ((2M+m)/m)/m
Find the acceleration using the formula you have.
Then set this acceleration = \frac{M-m}{M+m}*g (taking M as the heavier mass and m as the lighter mass of the atwood machine).
this will only give a relationship between M and m. is there any more information for the problem?
nope just that. I am guessing it might be sufficient just to have the relationship
i'm assuming g= 9.80
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
