Using Complex Impedances in these RLC Circuit Calculations
The discussion focuses on simplifying complex impedances in RLC circuit calculations, specifically addressing difficulties in algebraic manipulation. Participants emphasize the importance of rationalizing denominators and correctly applying formulas for parallel and series impedances. There is a notable exchange about dimensional analysis as a tool for verifying the correctness of equations, highlighting the significance of consistent units. The conversation also touches on the potential for high voltage outputs in resonant circuits and the need for careful checking of expressions. Overall, the thread serves as a collaborative effort to clarify complex impedance calculations in AC circuit theory.
NaS4
Learning
z=a+bj, angle = tan^-1(b/a) -
R = R, C = 1/jwC, L = jwL
Can someone help me with what i do next
For part (a), what you have done so far looks correct. You should continue to simplify the expression (get it into a simpler fraction). I'm assuming you were asking about part a - if not, do correct me.
[EDIT]: you may want to 'rationalise' the denominators of the fractions to help reach the required form. If you are taking an AC circuit theory class, I am guessing that you have seen complex numbers before? If not, let me know and I can explain further/ point you towards some resources.
Yeah part a
But when I try to simplify it it just goes horrible wrong
NaS4 said:
Yeah part a
Okay, why don't you type out your steps here and we can see where the problem is coming from.
Generally, we know that two parallel impedances yield ## Z_{total} = Z_1 // Z_2 = \frac{Z_1 \cdot Z_2}{Z_1 + Z_2} ## which follows directly from the formula you wrote. It might be easier to write out the final impedance that way
Yeah part a
But when I try to simplify it it just goes horribly wrong
I’ve seen it before. But there’s a lot happening here. And I don’t know where to start
1/Z_{total} = 1/Z_{1} + 1/Z{2} in parallel
Lets take ## Z_1 = R + \frac{1}{j\omega C} ## and ## Z_2 = j \omega L ##. The formula then becomes:
$$ Z_{total} = \frac{(R + \frac{1}{j\omega C}) \cdot ( j \omega L)}{( j \omega L) + (R + \frac{1}{j\omega C})} $$
Now you could multiply by, for example, ## j \omega C ## for the numerator and denominator. I don't think I can just give the answer
Likes etotheipi
And in series it’s Z(total) = Z(1) + Z(2)
Please see post #8. This question will mainly just involve being careful with algebra.
@NaS4 remember that if you have something of the form ##\frac{a+bi}{c+di}##, you can always multiply it by ##1##,$$\frac{a+bi}{c+di} = \frac{a+bi}{c+di} \frac{c-di}{c-di}$$and then separate into real and imaginary parts.
Likes Master1022
Yeah i get that. But the formula i got is not the same as the one you are using
It would really help to see some working. To get to the expression I have written, we can multiply the expression you have in the third line of your working by ## (R + 1/j\omega C ) ## and ## j \omega L ## (both numerator and denominator)
Likes etotheipi
Is this correct?
NaS4 said:
Is this correct?
In the beginning, ## j \omega L + \frac{1}{j\omega C} \neq j(\omega L + \frac{1}{\omega C}) ## as the j in the denominator should make it negative (i.e. ## j(\omega L - \frac{1}{\omega C}) ##)
I think you might also be missing a term where ## j \omega L R ## multiplies the ## R ## in the first line
Ahh yes I see it
Damn so many mistakes. Thx man. I’ll change it and post my next try
NaS4 said:
@Master1022 How does this solution look?
That looks correct to me! It might be easier to turn the ## (\omega L - \frac{1}{\omega C}) ## into a ## 1 - \omega^2 LC ## term (remembering to multiply through by ## (\omega C)^2 ## ). This looks like it will be easier to work with for the next parts of the question.
It is also useful to think about dimensions when working through these types of problems. Often seeing dimensions that match can be indicative of correct working (e.g. seeing a ## \omega ^2 LC ## or ## \omega ^ 2 RC ##)
Likes DaveE
Ok I’m lost now. How did you get (1 - w^2LC)
Apologies, so you can get ## \omega^2 LC - 1 ## and then multiply that term by ## (-1)^2 = 1 ## so your denominator becomes ## (\omega C R)^2 + (\omega^2 LC - 1)^2 = (\omega C R)^2 + (1 - \omega^2 LC )^2 ##. It's just a multiplication by 1 (won't matter because the term is squared).
You can also get there if you multiply the numerator and denominator by ## j ## in either line 3 or 4 of the working.
Hope that makes sense.
So just to clarify:
$$ (\omega^2 LC - 1)^2 = (\omega^2 LC - 1)^2 \cdot 1 = ((\omega^2 LC - 1)(-1))^2 = (1 - \omega^2 LC)^2 $$
@Master1022 So I've done most of the tasks now. But I'm abit unsure of task c) ii)
That 11.5k V sounds abit to high 😅
What happened to the denominator in the expressions for ## a ## and ## b ##? I think you have forgotten those?
[EDIT]: I realized that you included them in the working, but not the initial expression. Please ignore the above statement.
That is true and does definitely stand out to me. However, this is what can happen in resonant circuits with very high Q-factors... I just did a quick calculation, and the number I got was slightly larger than your answer (but on the same order of magnitude). Maybe another member might notice an error that I have overlooked
Also, in the expression for ## b##, I think the central term in the numerator should have the ## C ## as ## C^2 ##. However, I am not sure whether that makes much difference given the order of magnitudes. I will go back to check the original expression to ensure that your formula is exactly the same as what I got
Master thanks a lot for the help man. You really are a lifesaver
This is an incredibly useful tool when working with this sort of complex algebra. OK, actually, useful in most of physics, really. This allows you to spot errors in equations without having to go through the whole derivation. Maybe you won't know why it's wrong, but you will know it's not correct.
So, to elaborate on @Master1022s method:
R, 1/(ωC), ωL all have units of ohms. If I see a term in your equation like (R + L), I know without much analysis that it's wrong; that should be something like (R + ωL), or (R/ω + L). You just won't see solutions in physics where you have (ohms + volts), (force + energy), (flow + pressure), etc.; these rarely have any useful physical meaning. In the (R + L) example the units are (ohms + ohms*seconds).
BTW, you can't use this to verify correctness completely. It won't spot some errors, like the difference between (R + ωL) and (R + 1/(ωC)), or R vs. 2R.
If you want to know more look up "dimensional analysis".
Likes etotheipi and Master1022
Thx man. I’ll look up dimensional analysis
  • #31
It can get scary. Look for the useful bits. If they get too abstract (math, philosophy and such) that may a good place to stop, or not, if you like that stuff.
  • #33
Just a quick update, I have checked my expression:
$$ Z = \left( \frac{\omega^4 R L^2 C^2}{(1-\omega^2 LC)^2 + (\omega CR)^2} \right) + j \left( \frac{\omega L (1 - \omega^2 LC + (\omega R C)^2)}{(1-\omega^2 LC)^2 + (\omega CR)^2} \right) $$
and think it is equal to yours (thus we are either both correct... or both wrong 😅!)
Quick question about the problem statement: are the units of ## \omega ## a typo when it says Hz? Usually we expect ## \omega ## to be in rad/s (a conversion factor of ## 2 \pi ## is needed).
Am doing the calculations in a Python notebook, so will post pictures here to show how my calculations are resulting
  • #34
Yeah the w = 2(pi)f but since the question tells us that w is 200
  • #35
Ah okay, that explains the discrepancy I had earlier. After setting ## \omega = 200 ##, I did get the same value of the gain and the final voltage as you (give or take some rounding errors) - the computer output ## 11551.24... ## (V), so this does agree with your result.
Hope that is of some help.
  • #36
Master1022 I got nothing but respect for you man. Really makes me happy to see people like you helping out people like me
  • #37
Master1022 said:
Quick question about the problem statement: are the units of ω a typo when it says Hz? Usually we expect ω to be in rad/s (a conversion factor of 2π is needed).
It's very common for people to be sloppy about that. I guess they assume you'll know about the 2π correction.
Likes Master1022
  • #38
Happy to help, hopefully that answer is correct. One other sanity check is to see whether you can find a formula for the damping ratio of an RLC circuit with this setup and see whether it is very small (which is the only way such a large value of the gain is possible). I did have a quick glance on wikipedia, but I cannot see any similar variation. Regardless of the numerical values of the question, you did get the overall method correct (finding the transfer function and then calculating the gain).
I am going to ask @DaveE as I think he is more knowledgeable: can this topology of the RLC circuit be re-arranged into another form (eg. from the list on wiki here) such we can use the same formula for the damping ratio ## \zeta ##?
  • #39
The canonical form for this particular LCR impedance is:
Z(s) = sL⋅(1+sRC)/(1+sRC+s2LC), where s=jω (sorry, I have habits that are hard to break!)
Then if you define some common features: ω=1/sqrt(LC), Zo=sqrt(L/C), Q=1/(2ζ)=Zo/R
The quadratic term looks like 1+(1/Q)(s/ω)+(s/ω)2.
This looks very different from the homework problem which wants a solution as a+ib. Hence a lot of algebra ensues.
The "factored pole-zero" or "ratio of factored polynominals" form above is how we really do this in EE/Controls world. I gives much better insight into the dynamics of this circuit. It's also easier to derive, IMO. Also notice that the polynomials are dimensionless, except the leading sL term, which is ohms, of course.
edit: all of my ω's above (except s=jω) should be ωo, it's not that ω, it's a constant.
  • #40
Thanks for the reply @DaveE !
Agreed! (I also prefer working in the ##s##-domain)
Yes, that is correct. This leads to
$$ \zeta = \frac{R}{2} \sqrt \frac{C}{L} = \frac{10^4}{2} \sqrt{\frac{5 \cdot 10^{-6}}{20}} = 2.5 $$
which is odd because that doesn't suggest gain on the order of ## 10^3 ##...
Hmm, perhaps I ought to have another look over my algebra tomorrow to see if I come across any errors.
Thanks once again.
Likes DaveE
11K
