Euan12345
- 11
- 0
!An RF antenna radiates a "coherent" waveform (all of the same phase). What is the spacing between the receive antennas compared to the wavelength? If the spacing is small compared to the wavelength (not too small), you just use a mixer to determine the phase between the two received waveforms.Euan12345 said:the sources is a point source so no it isn't coherent. (also, when I said IR signal that was wrong. will probable be using UHF or VHF waves, with wavelength 0.1 m to 1m in length)
I don't know the spacing (S), will be less than half the wavelength however. so less than 50cm. What do you mean by mixer. Sorry my knowledge is lacking in this area.berkeman said:An RF antenna radiates a "coherent" waveform (all of the same phase). What is the spacing between the receive antennas compared to the wavelength? If the spacing is small compared to the wavelength (not too small), you just use a mixer to determine the phase between the two received waveforms.
A mixer is a multipler for the two signals. If they are the same frequency, you get a DC component out of that multiplicaiton. The magnitude of that DC component depends on the phase -- if they are in phase you get "100%" and if they are 180 degrees out of phase you get "-100%".Euan12345 said:What do you mean by mixer. Sorry my knowledge is lacking in this area.
The signal strength will be weak don't know exactly. The accuracy will need to be +/-0.5 degrees. I was going to repeat it multiple times then workout an average. There will be some interference but it isn't constant.Baluncore said:This is VHF radio direction finding 101.
The way to find the phase difference is to employ two identical receiver channels that share the first local oscillator. That way the phase of the IF, (or the baseband, if direct down conversion), will maintain the phase of the RF signals.
There are a few other possibilities, such as doppler DF.
1. What is the expected signal strength?
2. How accurately do you need the angular result?
3. Is there any interference?
thanks for your help, I will build it as part of a larger projectberkeman said:A mixer is a multipler for the two signals. If they are the same frequency, you get a DC component out of that multiplicaiton. The magnitude of that DC component depends on the phase -- if they are in phase you get "100%" and if they are out of phase you get "-100%".
Do you really want to build this (fun project!), or is this a paper exercise?
https://www.minicircuits.com/WebStore/Mixers.html
https://www.electronics-notes.com/articles/radio/rf-mixer/theory-mathematics-maths.php
This is not a simple problem. You are embarking on a lifelong interest in amateur radio, or a career in RDF and signals intelligence.Euan12345 said:I am however struggling to understand how the phase difference (∆ϑ) is found. Can someone explain how I could find this?
Baluncore said:This is not a simple problem. You are embarking on a lifelong interest in amateur radio, or a career in RDF and signals intelligence.
