Vaguely defined vector related question
  • Thread starter Thread starter FermatPell
    Vector
Vectors can be perpendicular through different representations, such as using the cross product or by illustrating their components in a three-dimensional space. The cross product of two vectors, like i and j resulting in k, exemplifies this relationship. There is some confusion regarding the specific types of vectors being referenced and whether the question is clearly defined. Participants express uncertainty about demonstrating the concept effectively. Clarifying the question's intent could enhance understanding and responses.
FermatPell
Vectors can be perpendicular in two ways. Show them!
none
I know a lot about vectors, but I'm just not sure what I'm supposed to do. Maybe demonstrate that cross product is anti-commutative?
Maybe just a picture of a vector with i, j, and k (x,y,z) components, each component of which is mutually perpendicular to the others? The cross product i X j = k is a good one.
Hi FermatPell! :smile:
I can't think of two ways … perpendicular is perpendicular. :confused:
What type of vectors are they talking about?
(and is that the exact question?)​
