Vector Analysis - Determining whether a vector field is conservative
Bill Nye Tho
n/a
∇ x F = 0
∂Q/∂x = ∂P/∂y
n/a
Given that no sketch of the vector field is given;
Is determining the curl of a vector field the most fail proof of determining whether it is conservative?
I'm just wondering whether or not determining ∂Q/∂x = ∂P/∂y is just as fail proof (Given that: F=Pi + Qj + Rk) because it seems like a faster method within the boundary of this course.
Bill Nye Tho said:
n/a
∇ x F = 0
∂Q/∂x = ∂P/∂y
n/a
What if ∂Q/∂x = ∂P/∂y, but ∂Q/∂z ≠ ∂R/∂y ?
Then the partials of Q and P will only be effective with i + j vector fields?
Also, the answer to your question would be that the field would only be conservative in the XY plane but not in the XZ or YZ.
I've not aware of that sort of distinction.
If ∂Q/∂z ≠ ∂R/∂y, then ∇ x F ≠ 0 , so the field, F is not conservative.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
