Vector Addition and Subtraction in Three Dimensions
  • Thread starter Thread starter fffff
    Dimensions Vector
To find the position vector D that completes the parallelogram ABCD, the discussion emphasizes the use of vector addition and subtraction rather than norms or unit vectors. The correct approach involves calculating vector BA as the difference between vectors OD and OC. Participants note that the initial method attempted was incorrect, highlighting the importance of clarity in vector operations. A visual representation of the vectors may aid in understanding the relationships between the points. Ultimately, the focus is on correctly applying vector principles to solve for point D.
fffff
Point A (2i +j 2k)
Point B (3i +2j +5k)
Point C (4i +5j -2k)
the point d is such that abcd in that order is a parallelogram.
Find position Vector D
ok so i start of like this but I am getting the wrong answer.
http://img511.imageshack.us/img511/5946/vectorak5.jpg
(BA)^1/2=(CD)^1/2
but its wrong.
It might be useful to make a drawing.
Yes, but are those equations correct
I've realized my error.
culd you tell me the point of the unit vector.
You don't need to do anything involving norms or unit vectors here, so the square root stuff is way off base. It's really just a matter of vector addition, and subtraction.
\vec{BA}=\vec{OD} - \vec {OC}
makes sense to me, the other equations don't really.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
