Vertical Circles: Centripetal Force & Tension
  • Thread starter Thread starter binbagsss
    Circles Vertical
In a vertical circle, the magnitude of centripetal force remains constant, but the tension in the string varies depending on the position of the object. At the highest point, the tension plus gravitational force contributes to the centripetal force, while at the lowest point, the tension minus gravitational force provides the necessary centripetal force. This variation in tension is due to the changing direction of gravity relative to the rotating body. The speed of the object can change due to energy conservation principles, as potential and kinetic energy interchange during the motion. Understanding these dynamics is crucial for analyzing forces in vertical circular motion.
binbagsss
Does the magnitude of centripetal force as well as the tension change in a vertical circle?
The net centripetal force don't change but as the direction of gravity wrt the rotating body change .. tension change
like, T+mg provide centripetal force when body is at highest point but its T-mg at lowest point
f=mv^2/r, why does v changee thenn? :confused:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
