Engineering Very basic circuits 1 question. Charge and current
The discussion revolves around calculating the charge q(t) from the given current function, 20 cos(10t + π/6)μA, with an initial charge q(0) = 2 μC. The user initially misinterpreted the integration of the current, leading to confusion over the correct final expression for q(t). The solutions manual provides the answer as (2sin(10t + π/6) + 1)μC, which the user initially thought should include +2 instead of +1. Clarification came when it was pointed out that the entire function represents q(t), not just the added initial charge. Ultimately, the user understood the correct interpretation of the solution.
A.J.710
Find the charge q(t) flowing through a device if the current is: 20 cos(10t + π/6)μA, q(0) = 2 μC
∫ i(t)dt +q(0)
I am studying for a test by working all the problems I can and then looking at the solutions manual. The solutions manual says the answer is (2sin(10t+π/6)+1)μC. I got the same thing except +2 at the end since q(0) is 2. It's really bugging me that I can't figure out why. Can anyone please explain?
If you plug in t = 0 to your solution and the manual's, which one gives the correct answer?
Ahh, got it now. Thank you. I didn't realize that's what it meant. I was just adding the q(0) but I didn't realize until you pointed it out that the entire function in itself is q.
