Very basic motion law - Newton's 2nd
  • Thread starter Thread starter 2clients
    Law Motion
In the discussion about Newton's second law, a scenario is presented where a 5 kg object on a frictionless table is connected to a 9 kg hanging object via a pulley. The key question is to determine the acceleration of both objects and the tension in the string. It is clarified that the tension in the string is crucial, as the gravitational force acting on the hanging object will accelerate both masses. A diagram is suggested to visualize the forces at play. Understanding the relationship between the forces and the resulting acceleration is essential for solving the problem.
2clients
a 5 kg object placed on a frictionless, horizontal table is connected to a string that passes over a pulley and then is fastened to a hanging 9 kg object. Find the acceleration of the two objects and the tension in the string.
F = ma
It just seems to me that if there is no friction the second object on the horizontal table should travel as the same speed that the 9.00 kg object falls. If there is no friction, then I don't see what force would be needed to "pull" the second object across the table, or how it would slow down the 9 kg object.
Thank you!
F = ma
Thank you!
Draw a diagram. If there is tension in the line then whatever force there is from gravity on the hanging weight will be used to accelerate both weights.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
