Viability of using a long steel pipe to send a magnetic signal
Using a 20-foot steel pipe as a communication medium raises concerns about efficiency and signal transmission. The idea involves using the pipe as a transformer core with primary and secondary windings, but the lack of a grounding return path and the presence of eddy currents could hinder performance. Acoustic signals may be a more viable option if noise levels are manageable, while experimentation is essential to determine the effectiveness of any approach. Some participants suggest using the pipe simply as a conduit for running wires instead. Overall, the concept requires further testing to assess its viability.
Robert31
I want to use a length of steel pipe as a communication medium. The pipe is about 20 feet long and the idea is to send some sort of signal along it that can be detected at the far end. I've had various ideas including using acoustic signals, or using the steel as an electrical conductor but I don't think I'll be able to ground the pipe at either end to complete the circuit. I therefore had the idea of using the pipe as a type of transformer core, with the primary and secondary windings rapped around either ends of the pipe. This would be an extremely inefficient transformer of course, I'm not even sure it would work, but I'm hoping just enough magnetic flux might pass through the pipe that it might be detected at the far end.
I would like to know if anyone had any thoughts on the idea, is it a viable concept? I haven't tested it yet but some concerns I have are that there is no return path for the flux except through air, the relative permeability of steel is nowhere near that of soft iron and there will probably be large eddy currents.
Any replies will be much appreciated.
Hi Robert31. Welcome to Physics Forums.
I think it's a case of try it and see. You may need more power than you hoped for. By communications, do you mean transmitting voice spectrum?
I'd back acoustic as viable, so long as there is not a lot of noise in an overlapping spectrum from whatever is happening in that pipe or in what it connects to at each end (or what falls onto it, or in what drives over it). Audio filters might clean up some of the noise.
Is this something to tinker with, or does it have a serious purpose?
experimentation will be the key.
Eddy currents reduce the apparent permeabiliy as frequency goes up.
I found that my 400 series 2" stainless bar stock worked best below 10hz.
Could just use the steel pipe as a conduit, run some wires through it.
Likes Nik_2213
i wish i'd said that. :redface:
Likes Nik_2213
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
