Water jet cuttng carbon fiber fabric
Cutting carbon fiber fabric with a water jet machine is feasible, but challenges include securing the material and preventing fraying. It's important to hold the fabric down effectively, possibly using a pre-made metal shape or weighted methods. Concerns about water affecting the fabric are minimal, but trapped water in the weave can disrupt the cut, so using an air jet to clear the area is recommended. Some professionals prefer laser cutting over water jetting for carbon fiber due to these issues. Overall, careful handling and preparation are essential for successful cutting of carbon fiber fabric.
thehitchhiker
Hello!
I've just received information that there may be a requirement to cut some carbon fiber fabric on the water jet machine in our lab. The party that wants the cutting done, requires an option that's quicker than using shears to cut it.
That's pretty much all the information I have at the moment and we have never cut the material before. So I know that carbon fiber can be cut on the water jet, but I'm not sure about how to clamp it down and how to keep it from moving around during the cut. I'm also unsure about whether or not abrasive will be needed. I'm guessing it won't be. Finally, will the CF fabric be affected by the water when it is submerged? I've heard something about the fibers swelling up and fraying.
I've only ever hand cut plain carbon fibre cloth but in the absence of a better reply...
I don't think carbon fibre will absorb water and swell up but the cloth would need to be dried well before being impregnated with resin. Perhaps they want you to cut "Prepreg" rather than plain woven cloth? Prepreg already has resin in it that is later heat activated.
Plain cloth can fray easily when it's handled - particularly on cuts that are parallel to the weave or at corners/points. I think it could be difficult to get cut pieces out of the water without it falling apart/fraying? I think Prepreg would be much less prone to this.
Thank you for your reply CWatters, it's the most helpful I've received from anywhere till now. I haven't worked with carbon fiber so far. I'm very unsure what it's going to be like and I have very little information about it at the moment. But I'm very excited to see how this goes about.
I was told that it will be just the plain woven fiber, but I'm yet to see what it will be like when it arrives. Our main concern at the moment is how to hold it down.
Do you think there would be any other issues if the water jet is used to cut the carbon fiber with resin?
The easiest way to hold down Carbon Fibre cloth for cutting is to pre make a shape in metal which replicates the required shape but which has clearance along the lines of cut just sufficient to clear the water jet .
Plate and cloth are then just weighted down .
If cutting table has widely spaced bars then pre make another plate to support cloth from underneath .
Carbon Fibre cloth does not respond well to punching through to initiate cuts and particularly to make small holes . Best where possible to punch through in scrap areas and then arrange easy run into the profiling cut .
Water is not a problem as such but there is a niggle problem in that gobs of water caught in the weave near the cutting edge can 'burst' and displace the edge fibres . Common solution is to use a vigorous air jet to disperse any residual water in cutting zone .
Some professional companies don't like cutting Carbon Fibre cloth with water jet and will always use laser cutting when possible .
Another way of supporting the cloth for cutting which is used sometimes for low value one off jobs is to put the cloth between top and bottom layers of something like MDF board and just cut through the lot .
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
