What are clipper and clamping circuits?
  • Thread starter Thread starter stupif
    Circuit
Clipper and clamping circuits are essential components in electronics used to modify signal waveforms. Clipper circuits limit the voltage levels of a signal, effectively "clipping" off portions of the waveform that exceed a certain threshold. Clamping circuits, on the other hand, shift the entire waveform up or down without altering its shape, ensuring that the signal stays within a desired voltage range. For detailed explanations and visual aids, resources like Wikipedia provide clear diagrams and in-depth discussions on these topics. Understanding these circuits is crucial for effective signal processing in various electronic applications.
stupif
guys, may you tell me all about the clipper and clamping circuit?
i am fresh in this topic. thank you
You could have a look at these links:
http://en.wikipedia.org/wiki/Clamper_(electronics )
and
http://en.wikipedia.org/wiki/Clipper_(electronics )
They discuss these topics with nice clear diagrams.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
