What are the forces acting on the crate on a frictionless ramp?
The discussion focuses on calculating the forces acting on a crate on a frictionless ramp. The crate, with a mass of 111 kg, is pushed up the ramp at a constant speed by a horizontal force F, which has been correctly calculated as 628.67 N. The gravitational force components along the x and y axes are provided, with the y-component being -943.023 N. The normal force is determined by setting the sum of all forces in the y-direction to zero, leading to a calculated normal force of approximately 1257.36 N. The participants emphasize the importance of ensuring all force components are accurately accounted for to confirm the solution.
tjbateh
In the figure, a crate of mass m = 111 kg is pushed at a constant speed up a frictionless ramp (θ = 30°) by a horizontal force F . The positive direction of an x-axis is up the ramp, and the positive direction of a y-axis is perpendicular to the ramp. (a) What is the magnitude of F ? (b) What is the magnitude of the normal force on the crate?
For part A, I got 628.67 N which is correct.
I do not have part B, but I do have some other information that I found, which is correct.
Gravitational Force along x-axis is -544.455 N
Fx component of the applied force is 544.45 N
Fy component of the applied force is -314.341 N
Y component of the gravitational force is -943.023 N
Acceleration components are zero.
And the normal force of the crate is in the positive direction of the y-axis.
Draw a free body diagram, put in all the forces and find what the normal force is. In this case it is not mg*cosθ, so don't use that. Remember that the acceleration in a direction perpendicular to the incline is zero.
would it just be 0? F=M*A...A=0, so F is equal to zero?
If by F you mean "the net force", in other words the sum of all the forces, then it is zero. That's because the problem is telling you that the velocity is constant. Constant velocity means zero acceleration which means zero net force according to Newton's Second Law.
ok so since the sum of all the forces is zero, could it be -628.67?
or should I find the magnitude of the gravitational force. And set F(g) + F + F(n) = 0?
In what direction is the normal force? The sum of all the components of forces in that direction must be zero. You know all the components of forces in that equation except for the normal force.
Does 1257.36 seem right?
I did (544.45i - 314.34j) + (-544.45i - 943.02j) + F(N) = 0
I get 0i + (-1257.36j) = 0
So F(N) is the Square Root of 1257.36^2, which is just 1257.36
I want to be completely sure of my answer, cause I only have one try left!
That looks about right if your components along the y-direction are correct - I didn't check them - but if you say they are, I believe you.
