What Are the Steps to Solve CDF and PDF Calculations in a Given Range?
The discussion revolves around a continuous random variable X representing current in a circuit, characterized by a given probability density function (PDF). Participants are exploring various calculations related to the cumulative distribution function (CDF) and probabilities within specified ranges.
  • Mixed
  • Participants attempt to verify the total area under the PDF, derive the CDF, and calculate specific probabilities such as P(X ≤ 4) and P(5.4 < X). There are questions about the relationship between different probability calculations and the implications of values outside the defined range of the PDF.
Some participants have confirmed calculations for the PDF and CDF, while others express confusion regarding the interpretation of probabilities, particularly for values outside the defined range. There is an ongoing exploration of the implications of these calculations, with no explicit consensus reached.
Participants note that the PDF is defined only for the interval [3, 5], leading to discussions about the behavior of the CDF and complementary cumulative distribution function (CCDF) outside this range.
_N3WTON_
The current in a certain circuit as measured by an ammeter is a continuous random variable X with the following probability density function:
f(x) = 0.057x + 0.272 if 3 <= x <= 5. It is 0 otherwise.
a) Verify that the total area under the density curve is 1.
b) Obtain the CDF
c) Calculate P(x<= 4)
d) Is P(3<=x<=5) strictly less than, strictly greater than, or exactly the same as P(x<=4)
e) Calculate P(5.4<X)
For part a:
\int_{3}^{5} (0.057x+0.272)dx = 1
So the pdf is confirmed
For part b:
F(x) = \int_{3}^{x}(0.057y+0.272)dy
= \frac{0.057}{2}x^{2}+0.272x - (\frac{0.057}{2}3^{2}+0.272(3))
F(x) = \frac{0.057}{2}x^{2} + 0.272x - 1.0725
This is from 3<=X<=5
For part c:
I said that P(X<=4) is exactly the same as computing P(3<=X<=5). So From the CDF above I did:
F(4)-F(3) = 0.4715 - 0 = 0.4715
For part d:
I said that it would be exactly the same
For part e:
This is where I am getting confused, for P(5.4<X), I thought the formula was:
1 - F(5.4). However, when I do this calculation, I get back a negative value, which doesn't make any sense. So I was wondering if my computed CDF is wrong? Another thought I had was since 5.4 is out of the range of the pdf, would the probability just be equal to 1? Any help is appreciated. Thanks
For part d, I am not sure I understand the wording...to me P(3<x<5) is 1, since it covers the whole range, so P(anything else) would be strictly less than that.
for part e, P(5.4<x) is the same as 1-P(x<5.4). Be careful not to plug an x value into your CDF which is not in the valid domain. I think all allowable x values are in [3,5].
Ok I cleaned things up a bit, I realized it was a little hard to follow. So what you are saying is my calculation for P(X<=4) is incorrect? This is NOT equal to P(3<=X<=5)? Also, for the last part I would compute 1-F(5)?
It looks like your calculation for P(x<=4) is correct. But it is NOT equal to P(3<=x<=5), since the latter is 1.
And, yes, for the last part 1-F(5) would work, or just look at the (piecewise) definition of the pdf and say what ##\int_{5.4}^{\infty} f(x) dx ## would have to be. Either way you get the same answer.
b) Obtain the CDF
For part a:
For part b:
For part c:
For part d:
For part e:
Since the density vanishes outside the interval [3,5], the CDF ##F(x)= P(X \leq x)## must satisfy ##F(x) = 0## for ##x < 3## and ##F(x) = 1## for ##x \geq 5##--no calculations needed. For ##x## between 3 and 5, ##F(x)## is given by some formula involving ##x##, and you have found it (but I have not checked it).
Similarly, the complementary cumulative ##G(x) = P(X > x)## satisfies ##G(x) = 1## if ##x \leq 3## and ##G(x) = 0## if ##x \geq 5##---again, without calculations needed. Of course, ##G = 1-F##.
12K
