What equation do you use for this?
  • Thread starter Thread starter kevinlikesphysics
kevinlikesphysics
a 4500kg helicopter accelerates upward at 2m/s^2 what lift force is exerted by the air on the propellers?
Use Newton's 2nd Law. (Don't forget to include all the forces acting on the helicopter.)
