What Forces are Involved in Torque and Equilibrium Problems?
The discussion revolves around a problem involving forces, torque, and equilibrium in a mechanical system, as illustrated in a provided diagram. Participants are analyzing the forces acting on a strut and a crate, including tension, normal force, and weights, while ensuring the system is in equilibrium.
  • Mixed
  • Participants explore the equations of equilibrium for forces in both x and y directions, as well as the summation of torques. There are questions regarding the completeness of the forces considered and the correct application of mass versus weight in calculations.
Some participants have provided guidance on ensuring the correct identification of forces and the need for additional equations. There is an ongoing exploration of the relationships between the forces and torques, with participants questioning assumptions about the forces involved.
There is a noted confusion between mass and weight, with participants discussing the implications of this on their calculations. The original poster expresses uncertainty about whether all relevant forces have been accounted for in their analysis.
odie5533
http://img404.imageshack.us/img404/248/sdaft7.png
The arrows on the diagram are drawn in, as are the labels (except for the angles).
[tex]\sum F_{x} = P_{x} - Tcos30 = 0[/tex]
[tex]T = \frac{P_{x}}{cos30}[/tex]
[tex]\sum F_{y} = N_{p} - 8900N - 650g - Tsin30 = 0[/tex]
[tex]N_{p} = 15274N + Tsin30[/tex]
[tex]N_{p} = 15274N + P_{x}tan30[/tex]
I think I'm missing forces, and probably making up a few. If anyone could check them over before I continue I'd really appreciate it.
you're off to a good start. make sure you have the weight of the box in kg. now you need a third equation, which comes from summing the torques about the pivot and setting that equal to 0.
Are all the forces right though? Am I missing any?
Here's the third equation:
The angle between the strut and the tension from the cable is 16 degress: 180 - 30 - (180 - 46) = 16
[tex]\sum\tau = Tlsin16 - \frac{1}{2}l650g(cos46) - 8900l(cos46) = 0[/tex]
[tex]\frac{P_{x}}{cos30}lsin16 = 325lg(cos46) + 8900l(cos46)[/tex]
[tex]\frac{P_{x}}{cos30}sin16 = 325g(cos46) + 8900(cos46)[/tex]
[tex]Px = \frac{325g(cos46) + 8900(cos46)}{sin16} = 26381N[/tex]
[tex]T = \frac{26381}{cos30} = 30462N[/tex]
[tex]N_{p} = 15274 + P_{x}tan30 = 15274 + 26381(tan30) = 30505N[/tex]
[tex]P_{tot} = 40330N[/tex]
[tex]\phi = 49 degrees[/tex]
i just noticed. in your summation of the forces in the y direction, you have the mass of the strut. mass is not a force, so it shouldn't be included in the summation of the forces. you have to find the weight of the strut. (i made a bad mistake by saying that the weight of the crate should be in kg. mass and weight are not the same thing). same deal in your summation of torques. torque is defined as the force times the moment arm, not the mass times moment arm. i think you should have it though. just play around with your three equations till you get it.
When I listed 600g, I meant the g as in 9.81 not grams or kilograms. When I computed the answers, I multiplied things by 9.81 wherever g is. I use g so that I get a more accurate answer. Am I using all the right forces though? Tension in cable pulling down and to the left, normal force from pivot on the strut pushing up and to the right, weight of strut going down, and weight of crate going down. Is that all?
  • · Replies 25 ·
