Why is Ferroelectricity Named After Iron?
  • Thread starter Thread starter Prashasti
The term "ferroelectricity" derives its prefix "ferro" from its analogy to "ferromagnetism," despite having no direct connection to iron or ferrous materials. Ferroelectricity refers to the ability of certain materials to exhibit spontaneous electric polarization that can be reversed by an external electric field. This concept was established in 1920 when Valasek discovered ferroelectric properties in Rochelle salt. The use of "ferro" reflects the historical context of the term, as ferromagnetism was already recognized at that time, leading to the adoption of the prefix to describe similar properties in electrical materials. Most ferroelectric materials do not actually contain iron.
Prashasti
In the word "Ferroelectricity", why has the word "ferro" been used when it has nothing to do with ferrous or iron?
Chemistry news on Phys.org
Ferroelectricity is a property of certain materials that have a spontaneous electric polarization that can be reversed by the application of an external electric field.[1][2] The term is used in analogy to ferromagnetism, in which a material exhibits a permanent magnetic moment. Ferromagnetism was already known when ferroelectricity was discovered in 1920 in Rochelle salt by Valasek.[3] Thus, the prefix ferro, meaning iron, was used to describe the property despite the fact that most ferroelectric materials do not contain iron.
http://en.wikipedia.org/wiki/Ferroelectricity
Likes 1 person
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
