What is the Angular Speed of a Toy Train's Wheel in a Rotating Track System?
The discussion focuses on calculating the angular speed of a toy train's wheel mounted on a rotating track system. The system consists of a wheel and track with a total mass of 3.59 kg and a radius of 1.79 m. The toy train, weighing 0.203 kg, achieves a steady speed of 0.551 m/s. The user successfully applies conservation of momentum principles to derive the angular speed, ultimately determining the angular speed to be 0.0165 rad/s.
  • Understanding of conservation of momentum principles
  • Basic knowledge of angular velocity and linear velocity relationships
  • Familiarity with rotational dynamics concepts
  • Ability to perform calculations involving mass, radius, and angular momentum
  • Study the relationship between linear and angular velocity in rotating systems
  • Learn about the conservation of angular momentum in various physical systems
  • Explore the dynamics of rotating bodies and their moment of inertia
  • Investigate practical applications of rotational motion in engineering and physics
Physics students, mechanical engineers, and hobbyists interested in understanding rotational dynamics and momentum conservation in toy or model systems.
ViewtifulBeau
A toy train track is mounted on a large wheel that is free to turn with negligible friction about a vertical axis as shown in the figure above. The mass of the wheel plus track is 3.59 kg and the radius is 1.79 m. Ignore the mass of the spokes and hub. A toy train of mass 0.203 kg is placed on the track and, with the system initially at rest, the electric power is turned on. The train reaches a steady speed of 0.551 m/s with respect to the track. What is the angular speed of the wheel?
I found the momentum of the train and used conservation of momentum and applied it to the track. I have a question though. What two momentums should I be conserving? should it be the ( masses of the entire train-track system) * w =(mass of the train only) *(given velocity (converted to w))?
w(t) = .30782 = (velocity/circumference) * 2*pi
I(t) = .65043 = m(t) * radius^2
I(system) = 12.15315 = (m(w)+m(t)) * (radius)^2
w(system) = w(t)*I(t) / I(system)
= .0165
not right! please help.
n/m i got it
  • · Replies 17 ·
16K
