What is the electric flux through the hemispherical surface?
The discussion focuses on calculating electric flux through a hemispherical surface in two scenarios: when the electric field E is parallel and when it is perpendicular to the axis of the hemisphere. For the parallel case, the initial interpretation suggests using the formula for electric flux, leading to the conclusion that the flux equals EA. However, it is clarified that the field is not parallel to the surface, necessitating the evaluation of the surface integral Φ_E = ∫E·n da, where n is the unit normal vector. In the perpendicular case, the correct approach also involves this integral, indicating that the initial assumptions may overlook critical aspects of the geometry involved. Understanding the coordinate system and the relationship between E and n is essential for accurate calculations.
physics231
A uniform field E is parallel to the axis of a hollow hemisphere of radius R. a) What is the electric flux through the hemispherical surface? b) What is the result if E is instead perpendicular to the axis?
Here is what I've interpretted so far. If the field is parallel to the surface, then the electric flux = EA cos(theta). With the angle being 0, I came up with the answer as just EA Therefore that is my answer on part a).
On part b) if the field is perpendicular then the electric flux is just = EA, therefore making that my answer. But I know this isn't right. What step am I missing? Thank you
Well the field is certainly not parallel to the surface in both cases. You'll have to evaluate the surface integral
\Phi_E=\int\vec{E}\cdot \hat{n}da
where \hat{n} is the unit vector parallel to the surface element da.
Hint: If you chose a coordinate system in which the origin is on the center of the hollow sphere and in which the z-axis IS the axis of the hollow hemisphere, then what are \vec{E} and \hat{n}?
