What is the maximum height a block will rise when the force is removed?
  • Thread starter Thread starter XphaythX
    Block Spring
To determine the maximum height a 0.2kg block will rise after the removal of an external force compressing a spring with a spring constant of 100N/m, the initial compression of the spring must be known. The block's weight contributes to the spring's compression, but without the specific value of the external force or additional compression, the problem cannot be solved numerically. Participants in the discussion express difficulty in proceeding without these key details, suggesting that a symbolic solution involving the force or compression distance may be necessary. The conversation highlights the importance of understanding the relationship between force, spring compression, and gravitational potential energy. Ultimately, the lack of complete information prevents a definitive answer from being reached.
XphaythX
I have tried all sorts of ways to solve this problem, but it has gotten the better of me.
A 0.2kg block is held in place by a force F that results in the compression of a spring beneath the block. The spring constant is 100N/m. Assuming the mass of the spring is negligible compared to that of the block to what maximum height would the block rise if the force F were removed.
Any and all help would be appreciated.
The block exerts a downward force on the spring (its weight), which compresses it. But an additional force compresses the spring more. Without any more info, (the force or added compression), I don't know how to solve it...
that's where I got stuck too. I found the accelration for the force on the spring but I don't know where to go from there.
Maybe the expected answer is a symbolic one with F or D included as a variable, rather than an actual number.
